Brian's '96
- Bronco Info: its blue has 450hp ,was built with 3 grand and your mom is jealous
Re: Brian's '96
ANY PICS OF THE HONDA ?
proud supporter of kaveman motorsports .
p.s .
I HAVE A FAN CLUB OF HATERS
p.s .
Re: Brian's '96
Haha! It's great to have you here Bryan!BLACKMARKETBRYAN wrote:ANY PICS OF THE HONDA ?
Re: Brian's '96
I think I asked this before but how do you get the rear shock mount in?
Also, that front bumper is gay.
Re: Brian's '96
It slides up between the frame rails. You push it through on one side then slide the other side up and across. Perty slick.philofab wrote:I think I asked this before but how do you get the rear shock mount in?
...and as far as the bumper. You should see the cocksucker that built it.
Re: Brian's '96
Nick wrote:Haha! It's great to have you here Bryan!BLACKMARKETBRYAN wrote:ANY PICS OF THE HONDA ?
you say that now ...................lol
p.s .
p.s .
Re: Brian's '96
Don't be eye'n my ride bra!
Re: Brian's '96
yikes wrote:BLACKMARKETBRYAN wrote:ANY PICS OF THE HONDA ?
you wanna run that thing squirle ? Ive got 1.6 liters of nastyness and a mean exausht leak that has got to add at least 27 horsepower
p.s .
p.s .
Re: Brian's '96
On a serious note ,i have ridden in , and been around this bronco many times ,it does extremly well and was built correctly ,for its intended purposes ,i am excited to see her run after the cage and front end get dealt with !
p.s .
p.s .
Re: Brian's '96
Couple of new goodies for the driveway queen. Swinger steering, new front suspension, new bumpers, relocated battery and the start of the cage....coming soon.
To use, or not to use. That is the question.
Re: Brian's '96
I say you slap those buckets on, make a shock hoop, and go play!
Re: Brian's '96
I'm leaning that direction right now. It just sounds like more fun than coilovers for some reason. Maybe it's because the rest of my Bronco is old school....the rear end, the rear suspension, the wheels, the owner, etc. Despite what people say, mounting these will be just as much work as coilovers and the cost difference is minimal. The adjustability and spring options are considerably less. Geometry is more critical. The 3.0 bypasses will make up for any inadequacies though. Haha!Nick wrote:I say you slap those buckets on, make a shock hoop, and go play!
- Bronco Info: 1990 Bronco EB
Re: Brian's '96
x2.Nick wrote:I say you slap those buckets on, make a shock hoop, and go play!
- robjs111
- Bronco Info: 1998 F150 , Bronco in Progress
Re: Brian's '96
What length king bypasses did you use for the rear?
Thanks.
Thanks.
Re: Brian's '96
12's
Re: Brian's '96
Alright. We've rekindled our relationship, so it's time to show a little love. Had to get something done today, so I started a new bumper. The main tube came out a bit wide, but not as wide as it appears in the pictures. It's actually about even with the glass, which is what I was after. Gotta have protection for them bushes that like to jump onto the trail.
Gonna plate the frame horns this time, just for a change and see how I like it. Also planning to build a Householder style kill'em dead pushbar that ties into the engine cage...that isn't built yet.
Re: Brian's '96
Not us. We're still in couples therapy.yikes wrote:Alright. We've rekindled our relationship....
Re: Brian's '96
Haha!
Re: Brian's '96
That looks good!
I guess you could say that you were my, and my s/o's therapist today!
Re: Brian's '96
Well, both radius arms are bent at the tabs/plates where they mount to the beams. The passenger's side was strangely much worse the the driver's side, where it took the big hit at the 500 last year. I was very disappointed to discover the plates are mild steel. They were easily massaged back into shape using just a vice and manual persuasion. I called Camburg to see if they would sell me just a set of plates, but they said it would be weeks before they would get some new radius arm components in, so I picked up some 5" x 1/4" cold finished flat stock that I'll weld on to double them up. They should hold up just fine after that. Nothing "yikesfab'd" has let me down yet. Haha!
Re: Brian's '96
yikes wrote:Well, both radius arms are bent at the tabs/plates where they mount to the beams. The passenger's side was strangely much worse the the driver's side, where it took the big hit at the 500 last year. I was very disappointed to discover the plates are mild steel. They were easily massaged back into shape using just a vice and manual persuasion. I called Camburg to see if they would sell me just a set of plates, but they said it would be weeks before they would get some new radius arm components in, so I picked up some 5" x 1/4" cold finished flat stock that I'll weld on to double them up. They should hold up just fine after that. Nothing "yikesfab'd" has let me down yet. Haha!
Hey Brian,
Can you take a look and measure the thickness of the Camburg plates.... I am curious if they went to a thicker plate in the newer designs.....
