"project orange juice"
- fomoco51
Re: "project orange juice"
Changed up the beadlock ring and added a rear bumper.
- uploadfromtaptalk1410044986588.jpg (134.88 KiB) Viewed 1930 times
- uploadfromtaptalk1410044976311.jpg (58.15 KiB) Viewed 1930 times
- uploadfromtaptalk1410044965221.jpg (69.61 KiB) Viewed 1930 times
I love the RC body! Looks great!
- fomoco51
Thanks steve
- fomoco51
Got some goodies today for the rear. Now I just need to get some more tubing.
- uploadfromtaptalk1410295694074.jpg (67.31 KiB) Viewed 1787 times
- uploadfromtaptalk1410295680866.jpg (59.22 KiB) Viewed 1787 times
- Hauls Assington
I really like your engine cage! I am going to start my engine cage tonight. May I ask what length limit straps you are running in the front?
- fomoco51
14" with adjustable clevis's.
- Hauls Assington
Nice thanks!
- fomoco51
Rear shock mounts.
- uploadfromtaptalk1412388873788.jpg (73.03 KiB) Viewed 1607 times
- uploadfromtaptalk1412388861860.jpg (79.41 KiB) Viewed 1607 times
- uploadfromtaptalk1412388849389.jpg (74.99 KiB) Viewed 1607 times
- uploadfromtaptalk1412388792317.jpg (65.24 KiB) Viewed 1607 times
- uploadfromtaptalk1412388775499.jpg (65.78 KiB) Viewed 1607 times
- fomoco51
Damnit keep forgetting to load the pics in order. Oh well its backwards.
- ChiroMatt
looking good
- fomoco51
Well the time has come. Shes ready, not 100% but good enough for huckfest. Gonna load her up this morning and hit the road. See ya in the dunes!!!
- uploadfromtaptalk1413469215274.jpg (51.68 KiB) Viewed 1536 times
Nice!!
- ChiroMatt
Looking good.
Want to hear how your suspension works...?
And any changes after your 3 day shake down and
Dune running.
Dune running.
- fomoco51
Well shake down went as expected. Suspension worked flawless, and even better with 4 adults. Sucked up the whoops!! Blew the spider gears friday. Welded em up friday night and blew em again friday evening while duking it out with hoon racings bronco. Which is a bad ass rig.
- uploadfromtaptalk1413769509621.jpg (40.21 KiB) Viewed 1442 times
- fomoco51
It was fun while it lasted.
- uploadfromtaptalk1414288921208.jpg (21.12 KiB) Viewed 1364 times
- uploadfromtaptalk1414288910417.jpg (71.21 KiB) Viewed 1364 times
- uploadfromtaptalk1414288897443.jpg (70.44 KiB) Viewed 1364 times
- uploadfromtaptalk1414288887986.jpg (64.38 KiB) Viewed 1364 times
- uploadfromtaptalk1414288874356.jpg (63.45 KiB) Viewed 1364 times
- uploadfromtaptalk1414288861052.jpg (48.26 KiB) Viewed 1364 times
Cool pics! Man you did a number on that rear diff huh? Was that from jumping it or did it just happen out of the blue from harder than normal use?
- fomoco51
Well tell ya the truth, she was doomed from the start. We put the rear gears In The weekend before, noticed the spiders were pretty bad and pittid. No time to find new ones and figured they'd last at least this trip. "Coming from a guy who puts at least 1k hp to the ground in his sand drag truck" well I guess they were worse then thought and pow. First good run she let go. Found a welding rig and welded em up. Then after a good run with hoon racing's bronco she came apart again. Along with my shift cable not adjusted right and being stuck in 1st and 3rd the transmission puked about a gallon or so out. So new carier and spider gears and a secondary transmission cooler are the first on the list. But hell she sucked it like a champ.
Sorry to hear it. I know how you feel. One year be did the run from Ensenada up through Ojos Negros and hit the big jump outside of town and brew the stock 8.8 limited slip diff. I think we were only at mile 29 on the Baja 1000 course or close to that.
That's awful, Both you and wrights stories.
- Bronco Info: 1993 Bronco, stock now but work in progress
Who's fiberglass is that? I really like that hood
