Page 1 of 1
10" Lowrance...... which models and what are the differences
Posted: Mon Oct 14, 2013 10:30 am
by tcm glx
Ok..... looking for some help here..................
Vic is looking to step to the 8" GPS (mine) and so I am likely going to pass mine into his ride, and step into a 10". What I am looking for is some help with the model numbers (Andy... which one do you have again?) and what the differences are, what to look for etc etc...
Chasetruck, I know you have some experience here, which model numbers should I be chasing down?
Re: 10" Lowrance...... which models and what are the differences
Posted: Mon Oct 14, 2013 4:05 pm
by ChaseTruck754
you going "old skool" or all fancy pants with the HDS model stuff?
If the latter, then you are out of my realm. If the former, many models do damn near the same thing.
The ones that are the LCX series are often used in boats as chartplotters & have a bit better background maps.
The globalmap series are definitely a good go-to.
Posted: Mon Oct 14, 2013 4:07 pm
by tcm glx
ChaseTruck754 wrote:you going "old skool" or all fancy pants with the HDS model stuff?
Sticking to the old school. I like the way they work and have learn how to use them. Thinking LCX 113... thoughts?
Posted: Mon Oct 14, 2013 4:09 pm
by ChaseTruck754
I think that's a pretty old one. Does it have the LGC-12w antenna? If so - I'd go newer
Posted: Mon Oct 14, 2013 4:13 pm
by tcm glx
ChaseTruck754 wrote:I think that's a pretty old one. Does it have the LGC-12w antenna? If so - I'd go newer
What is newer? LCX-110? How do I know which antenna is compatible?
Posted: Mon Oct 14, 2013 4:15 pm
by tcm glx
Found a couple of the LCX-113, and it says they use a LGC-3000 antenna.......
Posted: Mon Oct 14, 2013 4:20 pm
by ChaseTruck754
Then go with them. Maybe the 103 is the one I'm thinking of with the 12-w antenna. If they work with the 3000 antenna you're good to go.
Posted: Sun Oct 20, 2013 8:16 pm
by Silverslk
a ittle late but mine it a 9200C (haha, had to go look in closet at box)... its been too long.....
