pit radio questions
pit radio questions
I scored at the jy this weakend and found a Motorola radio and pickex it up for 15 bucks. Iam making this a pit/base radio and was wondering what frequencys i should program into it , And who should i take it to to get programed?
- Andy Jones
- Bronco Info: In the Works!
Re: pit radio questions
Wate till i get home fu@#er i will give you picks
- Andy Jones
Here u go andy
- 022212172815.jpg (276.35 KiB) Viewed 1062 times
Daren down at Autofab prgrams those radios for me.
Do you have a closer picture of the model number... that will help decipher if it is UHF or VHF, as well as what frequencies you can run on it. Also, if it is VHF 144-174mhz, you can change out the head unit to something a little bit more modern.
Hit me up, I am likely taking aout 10 of these to Autofab next week to get programmed.
Here u go i wish i known more about these things. What would it caut too reprogram?
- 022212175617.jpg (116.53 KiB) Viewed 1057 times
greaslife wrote:Here u go i wish i known more about these things. What would it caut too reprogram?
Any other part numbers on these? Programming costs varies
No there's no other part numbers
Thair is CC in font of the 4285
greaslife wrote:Thair is CC in font of the 4285
You want a code that say t73xt.......
witha little surch i found out that this is a vhf radio wiht opperating range 136-174mhz or 403-512mhz
and it a wide band . radio is fully reprogramable .
the codes on it were for fleets too drop production cost. found stuff on the web to mod them so goign to give it a try hell its only 15 bucks
This site decipher whether yu can use it: http://www.repeater-builder.com/motorol ... atrac.htmlgreaslife wrote:witha little surch i found out that this is a vhf radio wiht opperating range 136-174mhz or 403-512mhz
Found out its in 440use range and trying too figure out if i could change it to two meter any help
Unfortunately not.......
