Hey guys, I'm just putting a feeler out there to see if anyone is interested in 2 simple tools that I recently made. The first is a Clutch Perch Stud Remover which allows you to press out the studs after the heads have been air-chiseled off. The second is a Clutch Fork Installer that allows you to install the the Clutch Fork in the prongs of theThrowout Bearing. Both of these tools eliminate the need to drop the drive train too get inside the bell housing.
I made these tools after the retaining tab on my clutch fork broke while driving; I was not going to drop the drivetrain to get to the bell housing because I hate doing that. I was able to remove the studs and reinstall the clutch fork in the throwout bearing prongs after fitting the fork with a new retaining tab and the bell housing with countersink bolts and crimp nuts, with the drivetrain still in.
The tools I made are an unrefined, but I would be interested in producing a more professional version if there was an interest in them, as they saved me a ton of time and effort. Thoughts?
Interest Feeler: Clutch Perch Stud Removal Tool & Clutch Fork Install Tool
Re: Interest Feeler: Clutch Perch Stud Removal Tool & Clutch Fork Install Tool
Do you have any pics of your tools? They sound pretty interesting.
- 66WarPony
- Bronco Info: '89 XLT, Tired 302, 4" Lift, 33" Grabbers, D44 TTB/stock gears, Ford 8.8/4.56 gears
I intend in making this one out of stainless:
http://i1266.photobucket.com/albums/jj5 ... 165459.jpg
http://i1266.photobucket.com/albums/jj5 ... 165433.jpg
