1996 Solo Stage 4 Rebuilt 302 Phoenix AZ $13.5k
96UAV
Bronco Info: 96 XLT --Under Construction--
Post by 96UAV »
It's time to part ways with my Bronco. I've made some great memories with this truck but it's time to move on. I'm hoping it will find a good home within this community as I've invested so much of my time and money into this rig, I'd like it to live on and do what it was built to do. With that being said, she's NOT perfect. Not even close. I'll do my best to be as accurate as possible but this thread will be pages long if I laid every detail out.
History:
I purchased this truck, bone stock, from a well known seller on Ebay in 2008 with 86k on the clock. It's a 1996 XLT sport with the 5.0 HO and E4OD. I drove it stock until about 100k when I had a 6 inch pro-comp lift, G2 4:56 gears, wheels and 35x12.50 General Grabbers installed by 4wheel Parts. During that time the transmission blew a seal on a trip to Vegas and the transmission was rebuilt by an AAMCO in Vegas and has had no issues since then. I tried building a new 357W for the truck but that plan never came to fruition so I had a junkyard 302 stripped and checked. I rebuilt that engine using stock internals, new bearings, rings, and seals. The truck currently sits with 140,780 miles on the clock and the engine is basically new. During the break-in period of the new engine, the temp has gotten hot during short drives around the neighborhood and I believe the thermostat is sticking. I plan on replacing that soon and that problem should be corrected. It also has a tick during cold starts that sounds, to me, like a sticky lifter..but I don't know for sure.
Build:
Solo stage 4 with Kings & Deaver Q80's (front installed by me)--Rear installed by Solo
Fox bumps
Camburg/Kinetek limit straps
Front and rear bumpers built and installed by Solo
4:56 gears (open diffs)
(5) Method NV with Toyo Open Country RT's 35x12.50 17.
Rear brakes completely rebuilt
New fuel lines
New in-tank fuel pump
High flow Canton billet fuel filter
New battery
New ball joints
New wheel bearings (Timken)
New exhaust (Magnaflow stainless y-pipe with flowmaster 10 series with side exit)
New silicone vacuum lines
New Goodyear coolant/heater hoses
New expansion coolant/windshield washer tank
New Champion Aluminum radiator
Some of the bad:
As stated before, there is an engine tick during cold start/idle
The front diff didn't seal right when I installed the front end so the fluid has been drained and the front driveshaft removed until repaired.
Paint shows pinstripes but in excellent condition for its age (gets compliments all the time--when clean, of course)
Windshield is cracked
Interior carpet is original and has some stains
Missing the pins for the backseat
There's more, for sure, both good and bad. I have receipts for almost all of the work and parts.
Listing here before it goes to the public markets.
18K obo
Call or text is best. 440-503-7055
More pics available upon request
Located in Phoenix
Image--Image
Image--Image
Image--Image--IMG_3737 by schuy--ImageIMG_3750 by schuy--ImageIMG_3745 by schuy, on Flickr
biggiek
Bronco Info: 92 Ford Bronco
Re: 1996 Solo Stage 4 Rebuilt 302 Phoenix AZ $18k
Post by biggiek »
Damn!
96UAV
Post by 96UAV »
Just an update on the thermostat/overheating issue. I swapped the thermostat and burped the cooling system today using a bleeder funnel kit but unfortunately I still have air in the system with the engine getting hot. So, with that being said, it's either a bad water pump (which was brand new) or a head gasket leak. I used new head gaskets and torqued to spec and the machine shop said both head and block surfaces were true. I'm probably not going to have the time to address this issue so if someone is interested in purchasing the truck as-is, I'll obviously take this into consideration with any offers made.
Becks_Bronco
Post by Becks_Bronco »
Perfect Bronco, i really hope this sells quickly at your asking price.
Do you mind sharing where you got the Goodyear hoses? I cannot find them for the life of me...
96UAV
Post by 96UAV »
Becks_Bronco wrote:Perfect Bronco, i really hope this sells quickly at your asking price.
Thanks!
Now that you mention it, they're not Goodyear; they're Continental hoses.
https://www.summitracing.com/parts/cel-5003
Becks_Bronco
Thanks!
Badass, thanks man! My current upper hose is getting saggy and the fan is taking small shavings out of it.
Good luck with the sale, i really hope you see it go to a new home!
96UAV
Post by 96UAV »
Open to offers!!
96UAV
Post by 96UAV »
Taking offers
96UAV
Re: 1996 Solo Stage 4 Rebuilt 302 Phoenix AZ Price Drop 15K
Post by 96UAV »
Price drop: 15K
96UAV
Re: PRICE DROP $13.5k
Post by 96UAV »
PRICE DROP. $13.5K
96UAV
Re: 1996 Solo Stage 4 Rebuilt 302 Phoenix AZ $13.5k
Post by 96UAV »
Gotta move
Becks_Bronco
Where do you have this beast posted? I would have tho0ught it'd sell for sure by now.
96UAV
Post by 96UAV »
Becks_Bronco wrote:Where do you have this beast posted? I would have tho0ught it'd sell for sure by now.
Just here
Do you use Instagram? I would get it on there and bump the price back up to start. If you don't have it, email me some pictures, details and contact info. I'll post it on my account. Should get some hits. brian@cabunlimited.com
Becks_Bronco
Same, i'll happily repost!
Are you ok with someone posting to facebook for you?
96UAV
Post by 96UAV »
yikes wrote:Do you use Instagram? I would get it on there and bump the price back up to start. If you don't have it, email me some pictures, details and contact info. I'll post it on my account. Should get some hits. brian@cabunlimited.com
I do...but rarely and I use a private account. I'll send over some pictures! Thanks for offering to help out!
96UAV
Post by 96UAV »
Off the market.
Becks_Bronco
Did it sell? Or are you keeping it??
96UAV
Post by 96UAV »
Becks_Bronco wrote:Did it sell? Or are you keeping it??
It's going back on the market. I put a remanufactured long block in it.
96UAV
Post by 96UAV »
Back on the market. New remanufactured long block installed. All the bugs have been worked out. Still needs the front diff sealed back up. Other than that, she's ready to get broken in. I'm asking $18,500.
