*For Sale* Michael's 96 Sleeper Bronco *For Sale*
- guard
With changes in our family configuration and lifestyle it's time to let my supreme project go. Everytime I visit my garage I'm pained when I see my 1996 "Overland Sleeper" Bronco, literally wasting away. I start it up and take it on an errand at least once a month but there are no longer any trips planned, so it's just a damn shame to be reminded of that each day. This week the Bronco made a trip to Solo Motorsports where Bobby had the guys check it out from stem to stern
**FOR SALE**
$25,000 OBO (no trades)
(831) 206-2074
guard999@gmail.com
1996 Ford Bronco Eddie Bauer
Miles: 155,000
Engine: 5.8i
Gearing: 4.56
Differentials: Eaton e-locker FT, Detroit Truetrac RR
Biography
This vehicle was purchased from the owner of a Ford Dealership in Auburn, WA and trailered down to SoCal upon purchase. It was immaculate inside and out, a perfect start to a sleeper go-fast bronco build! Most of the build was completed by Southwest Performance in Ramona, CA. More recently it has had suspension repairs, tuning, and gone through in detail by Solo Motorsports in Covina, CA. This vehicle has been driven offroad on rock crawling trails in Big Bear and gofast trails like the Mojave Trail and two awesome expeditions to Baja, Mexico. It has been rigorously maintained with the best lubricants. Repairs have always been made professionally and correctly, usually an opportunity for an upgrade.
For most of its life it has either been garage stored or under a car cover. I stopped collecting invoices long ago, but I would estimate there is somewhere north of $45k invested. This Bronco is 100% smog legal and currently registered through 2018. It's road and trail ready as-is, engine is smooth, transmission shifts crisply, and no repairs needed. Reasonable offers will be considered and I'm not looking for any trades at this time. A truck like this would be near a 2-month build in a shop like Solo Motorsports...but it's here without the wait!
A quick note: This vehicle is not caged and has the stock leather seats and seat belts.
Build Sheet listed below. I've captured most of the work but it's not a 100% complete list. See below.
Suspension/Brakes
-Crossover steering kit. 1 3/8 .375 4130 steering links all fk stainless hiems. Tig welded 4130 pitman and rocker box
-Beams cut and turned boxed on the rear and 1 inch uniball pivots
-Radius arms and pivot brackets. 1 inch stainless uniballs and with all grade 8 or better hardware
-Coil-Over towers with crossbar and bumpstop mounts
-Front finish out kit. Bilstein 9100 c/os, 4 springs, hydraulic bumpstops, limit straps, and stainless steel brake lines
-Add acv to front shocks
-Rear shock mount underbody. Excepts 12 SAW and 12 short body Bilstein
-Rear shackles 1 longer then stock with delrin bushings
-Rear Q80 Deaver springs
-Single link rear track bar
-Rear 9100 Bilstein 60mm (2.65) body shocks
-Rear Wilwood disk kit, with E-brake
-Hydroboost brake upgrade
-SAGINAW steering pump upgrade (NAPA part number: 818429F)
-Remove ABS, add proportioning valve
-Tekonsha P3 Brake Controller
-EBC Slotted CryoRotors ft
-EBC Yellowstuff Pads ft/rr
Transmission/Drivetrain
- Mag-Hytec E40D/4R100 Deep Sump Transmission Pan http://www.mag-hytec.com/store/index.ph ... c54ccac9f9
- Punisher Valve Body trans shift kit
- Upgrade cooling line size of the E4OD
-CBR trans cooler (2 trans coolers in total)
- G2 Aluminum diff cover rear
http://www.4wheelparts.com/Drivetrain-a ... 240-2013AL
- Autofab engine & trans mounts
-Eaton e-locker Front, Detroit Truetrac Rear
- 4.56 gearing
- Chromoly Axle upgrade ft/rr
- Tom Woods custom driveshaft with 1-ton joints, clearanced for long-travel
Electrical
-Optima yellow top w/ Ruffstuff box http://www.ruffstuffspecialties.com/cat ... T-SIN.html
-Upgrade to 1/0 gauge wiring and clean/simplify in engine compartment http://custombatterycables.com/applicat ... bronco.htm
-Rigid D2 clear light set flush into stock bumper http://www.rigidindustries.com/D2-Set-o ... twod2s.htm
-Rigid Dually amber light set flush into custom Protofab rear bumper
-Warn 9.5xp winch hidden install
-Cobra CB and antenna install
-Race Radio
-200 Amp Alternator upgrade
-AIMS PWRB1250 1250 Watt Modified Sine Wave Compact Power Inverter in cargo area
-Fuel pump kill switch inside cab - additional security
-BAJA HID custom headlights
-Replaced all audio speakers and installed new head unit with clean wiring throughout
-Added rear stealth subwoofer
-Lowrance HDS-8 GPS with baja map chip
Additional
- Cooper Discoverer STT 35x12.5x15's
-CBR Performance Cooling System with dual Spal fans
-Protofab rear bumper w/ tire carrier http://www.protofab4x4.com/products.php?ID=00&ID2=74
-MagnaFlow catback custom exhaust
-K&N air intake
-Rock Sliders Powder coated (Hefty Fab)
-Minor axle truss w/ axle protection
-Custom fabricated skidplate
-H3R Performance HG100C HalGuard Fire Extinguisher - 1.4 lbs
-Anchor ties for rear carpet to secure cargo (4x) Mac Versatie 520415
Lubricants:
Motor Oil - Schaeffer Supreme 7000 Synthetic Plus 5W-30
ATF - Schaeffer #204S ALL TRANS Supreme Transmission Fluid
Power Steering Fluid - Schaeffer #204S ALL TRANS Supreme Transmission Fluid
Diff oil - Schaeffer #293 Supreme Gear Lube
Brake fluid - ATE Super Blue Racing brake fluid
**FOR SALE**
(831) 206-2074
guard999@gmail.com
Miles: 155,000
Engine: 5.8i
Gearing: 4.56
Biography
Suspension/Brakes
- 4.56 gearing
Electrical
-Race Radio
Additional
-K&N air intake
Lubricants:
- guard
Re: *For Sale* Michael's 96 Sleeper Bronco *For Sale*
Solo Motorsports has done the most recent work on the Bronco and has gone through it, like they would a used vehicle buyers inspection just this week. They took it for a test drive, tightened up some bolts and screws, adjusted some hoses, and told me it was ready to hit the trails. I was told by Bobby at Solo Motorsports that anyone with questions on its condition is welcome to call him.
Please feel free to PM me with any questions or to schedule a viewing.
Nice looking truck – sad you aren't able to use it more. I'd love to see more details on your belly pan. It looks great.
- guard
If I can get it up on a lift or find one I've already taken, I'll post it up. Thanks!
You bronco is very similar to mine. I bought it from Robert Craven.
I have a couple of questions for you. You got a couple of mods I’m interested in.
I’d like to speak over the phone if possible
Such an awesome build...what I wanted mine to become
- Becks_Bronco
If I had the $25k in disposable cash, i'd buy this in a heartbeat. Best of luck with the sale! this is a PERFECT build.
- funinthesun95
nice
- guard
*Sold!*
"As-Is! No warranties expressed or implied."
