1982 Bronco 4x4
1982 Bronco 4x4
Thinking about selling this 82 bronco. I really don't have the room for it. White/blue on outside with blue interior. Not a whole lot of electronics to break down on you in this truck. Almost like a classic. Good starting point for a Prerunner or race bronco. 35 years old makes it a classic truck and can be ran in the vintage 4x4 class of Norra. Looking for $1500 complete or $500 without wheels or axles. The more I sit in it the more I fall in love so hurry up if you want it haha. It runs and drives but needs some love. Everything is stock so I will more than likely pass smog after a tune up.
The good:
-351w with a carb set up. Can be easily built up without expensive efi mods
-C6 trans. All around good,non-electronic off-roading transmission.
-9" rear axle with factory limited slip. Stock gearing.
-bolt in axle front thirdmember. No c-clips so you can run a locker if you want to.
-manual x-fer case. No electronics to break.
-factory forged aluminum alcoa wheels
-power windows
-has AC but needs to be charged
-cruise control
-no major rust issues
-body is fairly straight with no dents except on top of tailgate.
-sweet roof rack
The not-so-good:
-no door lock keys
-dent on top of tailgate
-paint has a nice patina. Rat rod bronco would be bad ass.
-needs a new mechanical fuel pump
-needs ignition wires hooked back up correctly.
-top of dash pad has some cracks.
-center of steering wheel needs a new panel
-carb could use a cleaning
-rear window doesn't go down
-owes like $500 in back fees.
-needs a new headliner
S00TLYFE
Bronco Info: IT RAPTOR NOW
Re: 1982 Bronco 4x4
Post by S00TLYFE »
interior looks good for its age. wish this would have popped up when i was looking because i actually wanted a bullnose
1982 Bronco 4x4
S00TLYFE wrote:interior looks good for its age. wish this would have popped up when i was looking because i actually wanted a bullnose
It could still be yours ;) just send me back the axles and you can have it for $500 haha.
1982 Bronco 4x4
Needs to be gone this weekend. $200 for the truck minus axles/wheels. Will drive onto your trailer but I need the axles and wheels back
1982 Bronco 4x4
Ok. If anyone is interested. I am swapping an 8.8 into it and swapping the front diff out for one from a 95 to keep the same stock gearing together. Need to get atleast $400 with the swapped in axles. Also have a factory limited slip front pumpkin with stock gearing. These are very rare and you don't have to do any kind of sketchy mods to eliminate the c-clip because the factory LS uses the c-clip unlike an after market LS. I will trade for a truetrac or looking to get $400 for the complete pumpkin ready to go.
damon1272
Re: 1982 Bronco 4x4
Post by damon1272 »
PM sent
westco
Re: 1982 Bronco 4x4
Post by westco »
Is this still available? I need the emissions equipment for a buddys Bronco and i could use the tranny and engine
