Full Build Bronco 550hp rolling chassis FOR SALE
dkex34
Bronco Info: 89 bronco
Post by dkex34 »
http://www.gofastbroncos.com/forum/view ... Full+build
For sale I have my full build bronco. I've lost interest in the build. Life changes and it's time to move on. It is an entire rolling chassis. There is is $20k in labor into this not including parts or materials. Everything listed below is what is included. Located in San Diego. The link is the write up on it.
$15k cash or possible trade for something of value in the $20-25k area.
Please email or text for info
760-415-46twotwo
Dkex34@yahoo.com
Powertrain
- Engine
Lq4 vortex 6.0
Lunati cams, lifters and springs
L92 heads
Ls3 corvette intake
575hp
RPM full fabricated headers and Exhaust system
Motor has been pushed back and lowered to allow for lower center of gravity
- Transmission
Th400 using culhane parts
- Transfer case
NP205 built to handle 600hp
Dual Billet shifter to allow for separate front and rear locking.
Chassis/Fab
- Welding
90% of all welding is TIG welded rest is MIG
- Tubing
Uses 1.75" .120 wall Chromoly & DOM main structure tubing
Misc tubes are 1.25"-1.5" .120 wall Chromoly & DOM tubing
- Frame/Chassis
Entire frame is fully boxed and plated front to back
Rear is cut notched and boxed in rear to allow for more up travel
- Sheet Metal
All inner panels have been removed exception of firewall and has been fully sheet metal paneled and bead rolled.
Suspension
- Solo Motorsports
4.5" over per side TTB beams
Full replacement axles (not cut and extended like most)
4:88 gears
- Rear suspension
4 Linked rear suspension
Leduc sway bar and sway bar arms
Parts
- Rearend
Tube works TT rear housing and Jamar custom 5x5.5 full floater hubs
- Front knuckles
BMS fabricated front knuckles
BMS custom 5x5.5 front hubs to allow for 14" rotor
- Radiator & Coolers
CBR custom size radiator w/ dual 18" fans
CBR large oil cooler
CBR large trans cooler
- Fuel Cell
45 gallon Fuel Safe fuel cell
- Intake
UMP intake system
- Tires & Wheels
(5) 37" BFG projects
(5) Method Beadlock Wheels
- Fiberglass
McNeil Racing 6" over and raised front and rear fenders
McNeil Racing induction fiberglass hood
- Misc Parts
Sparco disconnect steering wheel, dual fuel pump setup and k&n fuel filter, full replacement headlight and taillights, Art Carr shifter, I have box's full of misc parts And new molding.
1Hondalover
Re: Full Build Bronco 550hp rolling chassis FOR SALE
Post by 1Hondalover »
15 cash eh? Can you please elaborate on the big picture? Does it run and drive? What needs to be finished? Obviously exterior paint and some interior finishing.....
Plumbing, wiring, gauges, glass, etc?
Thank you.
dkex34
Post by dkex34 »
Does not run and drive. Needs to be Plumed and wired to do that. Also will need drive shafts and rear axles and third member. Everything listed is what you will be getting. I also have Jamar TT 6 piston calipers and front coilovers and bypasses along with rear coil overs, and nitrogen bottle and jack mounted in back for an additional price.
Car54
Bronco Info: Don't have one
Post by Car54 »
Should of sold it to me that weekend when you came ocotillo wells
mofomotorsports77
Bronco Info: 1995 ford bronco
Post by mofomotorsports77 »
Did this ever sell?
eoffroader
Bronco Info: 1994 bronco 4.5 beams bilstein c/o behind the beam rad arms 456 front and rear f53 deavers blue inte
Post by eoffroader »
Ya and it got parted out after
eoffroader wrote:Ya and it got parted out after
That's just too sad.
damon1272
Post by damon1272 »
Don't worry. She is in good hands and will come back somewhat different.
damon1272 wrote:Don't worry. She is in good hands and will come back somewhat different.
Thats good to hear!
