1996 Bronco XLT 5.8l 140k miles with Stuff
Unfortunate time has come, and I think I've made the decision to let the Bronco go... asking $15k or best NO TRADES with a bunch of parts not yet installed
clean title, registration just paid, passed smog easily last year, I'm the 2nd owner, have the original window sticker and most of the receipts from the first owner.
probably forgetting some stuff, but my build thread is here http://www.gofastbroncos.com/forum/view ... =33&t=3258
Good
Front suspension
SWP cut/turned/clocked uniball beams
SWP Radius Arms with uniballs
SWP Bolt on coilover/bypass towers
SWP custom K&N filter mount
SWP radiator overflow/washer mount
Bilstein 9100 Coil-overs with ACVs - Front
AGM coil over sliders
Fox hydraulic bumps
3/4 ton ambulance steering
Rear suspension
SWP Upper shock mount
Bilstein 9100 4-tube bypasses
Deaver custom Q80+2 leaf springs
SWP relocated/welded spring perches
SWP custom shackles
SWP rear single link traction bar
Exterior
Michael Cox Racing, tig welded custom front bumper - powdercoated
Aurora 40" 400w combo LED Light bar
Aurora 40w LED Fog Cubes
McQueen Prototype Design fiberglass hood
Protofab rear bumper with tire swing, reinforced
Aurora 40w LED Dust/Back up light
BajaHID (TCMGLX) HID Projector Headlights
Clear Corner/turn signals
35" Cooper ST MAXX's, 70%+ spare is new
stripped/polished Factory Alcoas (have center caps)
Warn Premium Hubs
Interior
Maratrac "race radio"
Lowrance 8" HDS GPS
Alpine mrv amp for 4 main speakers
Alpine mrv amp for sub
Alpine 12" Type R sub
Mastercraft Baja XD front seats in grey vinyl
Stock grey leather rear bench
12" Tuffy grey stereo security console
Other Details
ABS Completely removed
Punisher valve body
MagHytec trans pan
Brand new fuel pump
Distributor less than 2yrs old
Replaced electric shift BW1356 with Manual Shift BW1356
winted tindows
Parts not yet installed
SWP Single Swing Steering (used)
SWP modified 5 bolt spindles; double sheer (used)
SWP custom pitman arm
Champion 4-row aluminum radiator (new)
Autometer steering column 2 1/16" gauge mount (new)
Autometer 2 1/16" pro trans temp gauge (new)
Mag Hytec rear diff cover (used)
replacement windshield cowl - currently white (used)
additional plate style trans cooler (used)
Momo steering wheel adapter (new)
Custom Sparco wheel
SpinTech 6441 3" muffler (new)
Bad
body ain't perfect, has a couple dings/scratches
SWP Single link has a couple cracks on the frame side bracket, I will have this fixed by Mark Sr.
shell is faded (have some paint to take care of that)
hood is still black gelcoat not painted yet
driver door panel has typical forearm crack
interior is 20yrs old...
some of the window weather stripping could stand to be replaced
rdcjuanb
Re: 1996 Bronco XLT 5.8l 140k miles with Stuff
Post by rdcjuanb »
Good luck, saw this coming when you got that nice jeep. ha ha I will trade mine for a YXZ golf cart. I am loving those things.
rdcjuanb wrote:Good luck, saw this coming when you got that nice jeep. ha ha I will trade mine for a YXZ golf cart. I am loving those things.
LMAO ... I know you did... Those Yami's are nice, wonder if they are going to come out with a 4 seater...
SOLD
PaleRider
Post by PaleRider »
CongratZ!
