Way too much time and money spent to sit in the shop doing nothing. Less than 500 miles on all brand new running gear.
Frame mounted DOM family cage. Linexed interior, HID lights, LED interior /cargo / backup lights , 2 batteries w selector switch in locking consol. 3 point belts for all 4 seats.Wild Horses S Steel windshield frame.
Body/tub in good cond in black primer. Top has rust issue along rain gutter seam. Not a rotted out South / East rig at all.
351W Edelbrock A heads/intake ,roller cam, forged, all machine work done and balanced ,Howell fuel injection, Deep sump pan, accusump oil accumulator ,Alum rad , HEI ETC.
New Atlas 4-1 / NV 4500 1350 CVs , custom x member / integral skid plate . 4 WDB w CNC master cylinders and balance bar.
Rear axle trussed Moser 35 spline , ARB, 4.56, True High 9 high pinion center section $$$$ (don't even like to think of what this all cost) WH 4 " lift leafs with 2.5 Fox coil over bodies ready for 4 link.
Front axle Currie 9" 31 spline , ARB 4.56 , high steer , Track bar frame and axle mount custom for reduced bump steer and tire scrub Fox 2.5 coil overs , custom rad arms .
5 37 x 17 Grabbers on Method beadlocks , 5/8 studs
2 custom steel fuel tanks , 2 fuel filters
Truck is very well built. Like any project it is not perfect. 1 hr North of Sacramento airport like any costly thing you should come see it first.
23k extremely firm may take 1000cc razor or YXZ or toterhome in trade.
Russ 530 68two 70three7 bphillips at dosriosinc . com
Email for pics
1969 Bronco
Re: 1969 Bronco
Someone should jump all over this beast. Mechanically it is sound throw your favorite color on it and you have an awesome and very capable Bronco. I honestly didn't even see it listed until now. I know Russ has a ton of dough and time in this beast. Russ is a good friend of mine so I know these things for a fact.
- Bronco Info: 69 Bronco , 78 Bronco , 75 f 250 x cab , TL race truck
Re: 1969 Bronco
Thanks Brandon. Will sell less wheels and tires to knock $2,500 off the price. Heading to NORRA the 23rd with an empty trailer,could deliver easily.
Re: 1969 Bronco
sold good guy hope you have fun with it
