Hi All,
The time has come to move on. I loved this little focus but I'd like to be back in a SUV (hopefully a pre 95 explorer for that sweet TTB potential) now that I don't have to commute to work.
It was washed and hand waxed once a month with regular checks of fluid levels and tire pressures to make sure it was always running it's best. I have driven it to Tucson, AZ and back so it has no problem going short or long distances. The car has some minor scratches and a door ding or two but overall looks very good. The interior is perfect.$2800 obo.
-2.0L Zetec 16v DOHC engine with 168,000 miles and automatic transmission
-Power windows, locks, cruise control, tilt wheel, cd/mp3 player, rear spoiler, and premium wheels.
-Exterior- 8/10, Interior- 9.5/10
-Clean Title
-Avg 24-25 mpg commuting, 27-30 highway
-Registered until Dec 2015
-Never smoked in
-Over $3000 invested in maintenance and aftermarket parts- see below
-Will be smoged on 8/1/15 so buyer doesn’t have to worry about that.
Maintenance performed-
-New front brake rotors and brake pads installed by previous owner right before purchase
- Driver rear window motor and regulator replaced ~158,000
- Alignment performed~158,000
-Motorcraft spark plugs and wires ~159,000
-Transmission shift solenoid A and MLP sensor replaced, fluid changed by Diablo Transmissions~160,000
-Passenger side motor mount replaced with OEM Motorcraft YS4Z-6308-BA ~160,000
-Rear shocks replaced with KYB Excel G and KYB upper mounts~163,000
-Valve cover gasket replaced with FelPro VS50553R gasket~163,000
-Oil change at Concord Ford with synthetic blend oil and a tire rotation~163,000
- Tire rotation, synthetic blend oil change, and passenger side outer tie rod replaced (Moog) by AA Automotive 7/28/15 ~168,700
Aftermarket additions-
-16x6.5 MSW Type 85 wheels w/ 205/55R-16 Bridgestone Potenza S-04 Pole Position SL- Installed brand new on 10/13/14~9,000 miles on them now
- Kenwood Excelon KDC-X598 headunit, Kicker 40CS684 6x8's in all 4 doors
-Sylvania Ultra headlight bulbs
- CFM Billet Shorty Radio Antenna (comes with original)
- CFM Lower Engine Torque Mount (“dogbone” rear engine mount) - not installed but comes with car- was actually the passenger engine mount that was bad and replaced.
-LED license plate light bulbs with new housings
-Clear corner lights
-Smoked clear front grille turn signals with amber bulbs
-Trunk lid de-badged
-Quality floor mats installed in all foot wells.
2002 Ford Focus Sedan SE- SF Bay Area, CA
- Bronco Info: White 1993 5.8l XLT
