1993 Ford Bronco XLT 5.8L-ABQ, NM
Madmaxwell87
Bronco Info: White 1993 5.8l XLT
Post by Madmaxwell87 »
Owned since 3/2020. Passed CA smog when I bought it and NM smog in late 2022. Selling it as it does not fit in with the type of wheeling we do and would rather see it get used then sit.
216,918 miles
$18,000 OBO
Modifications
• F and R axles rebuilt (Moog ball joints, all bearings) and regeared to 4.56, limited slip in both axles (Eaton Truetrac), converted to manual Warn hubs by AVS (drain added to front axle)
• Solo Prerunner Front bumper- professionally painted.
• ProtoFab RockSolid Double Rack rear bumper with jerry can and spare tire-reinforcement bracket fabricated and installed by AVS (led license plate bolts)
• Rocky Mountain Broncos rock sliders
• (5x) 33x12.5x15 Mickey Thompson Baja Legend EXP installed at 216,818
• (5x)15x8 Vision Manx wheels
• Desolate F350/Ambulance steering, Redhead steering box and pitman arm
• Desolate Stage 1 2” leveling kit with dual Bilstein 5100s
• Desolate center console with Tuffy center console (Element E50 fire extinguisher and mount on rear)
• ProEagle Kraktos 3-ton big wheel jack and mount
• Desolate Transfer case skid plate
• Desolate Dana 44 TTB Bash Guard
• Desolate Fuel Pump Access Panel
• Desolate Dash Brace
• RuffStuff rear differential cover with lube locker gasket
• Rear add a leaf and Bilstein 4600s
• PRP Daily Driver +2” width seats on Solo seat mounts
• Rugged Radio 50w GMRS radio, external speaker and magnetic antennae mount on roof.
• Garmin Overlander and charging mount with hard mounted reverse camera.
• 3M 15% tint professionally installed by Tint & Trim Factory on all windows in July of 2022
• LED reverse lights in aftermarket housings, LED 3rd brake light and tailgate light strip
• Magnaflow muffler
• Pioneer DEH-24220BT stereo with Kenwood KFC-1696PS in front doors and Pioneer TS-A682F in the rear panels
Maintenance
• Motorcraft spark plugs, wires, distributor cap, rotor and coil
• Koyorad radiator, cap, upper and lower hoses and reservoir
• Fuel Filter, Injectors, IAC valve, EGR valve, position sensor and solenoid/motor, Front passenger O2 sensor
• Battery replaced 6/20. All cables upgraded with kit from Custombatterycables.com
• Front brake calipers, pads and extended brake lines
• Rear brake drums, shoes, wheel cylinders and hardware
• Serpentine belt, belt tensioner and idler pulley
• Moog Radius arm and axle pivot bushings
• Moog Rear sway bar end links and bushings
• Window motors (tailgate window too)
• Motorcraft power steering pump and pulley
• Bosch alternator
• LED dash and map lights
• Husky floor liners
• Oil catch can
• New smoked headlights and Sylvania SilverStar Ultra bulbs
• Fuel filler tube
• Front and rear window weatherstrip/ window scrapers replaced inside and out.
• Transmission fully rebuilt with new torque converter and transfercase resealed (pan with drain plug added) by Tranco in November of 2022
• Rear driveshaft rebuilt while transmission was getting rebuilt.
Comes With
• Solo 30” single row led bracket kit
• Solo Motor Mounts
• Threat Extended Rear Upper Shock Mount kit with hardware
• Delphi fuel pump
• Lots of stock parts and Chilton repair manual
Issues
• AC not working- compressor won’t turn on. It was professionally topped off in early 2022 and it held vacuum fine. It’s been ice cold up until the last time I took it out on 9/30/23. The compressor won’t turn on. It seems like it’s the low-pressure switch.
• Rear window dash switch does not work. It used to but has stopped. Window works fine with the key in the tailgate. Dash switch and window motor are new.
• Paint faded on hood and passenger front fender.
• Dents in rear quarter panels
White 93 5.8L XLT
Madmaxwell87
Re: 1993 Ford Bronco XLT 5.8L-ABQ, NM
More photos-these are the ones that fit. I have more and can take more of anything needed.
White 93 5.8L XLT
Madmaxwell87
$17k for GFB only
White 93 5.8L XLT
Madmaxwell87
$15k obo
White 93 5.8L XLT
Madmaxwell87
$14k.
Lots more pictures to share and a video, just too big to host here
White 93 5.8L XLT
Madmaxwell87
Waterpump, thermostat and gaskets replaced to get rid of leaks
$12,500
White 93 5.8L XLT
Madmaxwell87
Sold
White 93 5.8L XLT
