1994 Ford Bronco XLT.
5.8L, automatic, 4x4
White with Grey interior. Power door locks, windows and mirrors, push button 4x4.
Listed on FB Marketplace
George: (two oh eight) 831-5351
I purchased the Bronco in 2012, had it in Arizona and Fresno, CA until moving to Idaho a few years ago.
Suspension system built by Threat Motorsports. 16” travel front, 18” rear.
I will attempt to list all, probably forgetting some items.
-Double swing race steering, stronger, faster turn rate for quicker response and eliminates bump steer.
-Dual rate 2.5” King Coil overs with adjustable reservoirs in the front.
-Custom coil buckets with engine bay cross brace.
-Extended radius arms, cut and turned and reinforced axle beams.
-Deaver Q80 rear leaf pack with 2.5”x 10” Sway Away shocks.
-Raised rear shock mount for increased travel.
-PSC power steering pump ported for remote steering ram, PSC power steering reservoir with external cooler.
1994 Bronco 351W Threat Suspension Kit. Interior rebuilt
- Bronco Info: 1994 Bronco XLT 351 Proto Fab rear bumper. Threat Motorsports C&T, Coil spring, Deaver Q-80 SAW
