95 Bronco XLT
LvSteve
95 Bronco XLT
Post by LvSteve »
5K mil or less on powertrain. 7K mil on suspension. 351w stroker 427w; E4OD; BW1356 manual.
All power option work. Cruise control needs to be reinstalled. No rust Nevada based rig built for trail & desert. 35x12.50r15 BFG on American Racing AR1725861 wheels includes spar; Deleted ABS, 3G alternator 240A; Saginew pump; Hydroboost; LED lights inside/out; Fiberwerx hood with Autofab front and rear mounts; 4 core alum radiator & duel electric fans; 3" y pipe to 3.5" exhaust; Master craft frt seats; Kenwood audio. Fosgate amps. JL audio. Mb Quarts. Fresh carpet kit with Noico. Sound deadening mats. New weather strips. Dual batteries X2 power AGM. mounted inside drivers frame rail by T Case. Comes with many extras parts (tailgate; shifter; tire carrier; jack)
Engine build 7/2018:
• Coast High Performance Stroker 427w
• Tuned 91 octane 440hp/425tq at 5800rpm to wheels
• Forged internals Neutral balanced
• Accufab mid length headers
• 95mm PMAS mass / 90mm accufab throttle body
• 60psi EV6 Siemens injectors
• Edelbrock Super Victor EFI intake , Elbow & fuel rails
• XRP fuel lines & fittings
• Walbro 255lph fuel pump with new sending unit and fuel filter tube
• Canton fuel filter
• Aeromotive fuel regulator
• Milodon 7qt oil pan # 30501 with dip stick, Windage trap, pick up tube, main stud girdle
• Melling HV oil pump kit
• 1.7 Roller rocker
• Afr 195 heads
• 2 custom grind cams with lifters
• Complete OB2 engine bay & dash wiring harness
• Race muffler
• Autofab Super duty motor mounts
• Custom tuning software (Core) with data logger and wide band O2 sensor & Laptop w/IDS for direct flash to pcm
Engine dyno: https://www.youtube.com/watch?v=LkYJx67XKik
Transmission build 11/2017:
• E4OD trans build to 7.3L diesel truck specs.
• Red Eagle clutches and steels with 4R100 drum and billet internals.
• ATS converter
• Hays flywheel neutral balanced.
• Derale deep pan #14208 & trans cooler with electric fan & temp sensor plus oversized OEM cooler
• SunCoast parts
• built To 700 hp & tq.spec
T-Case:
• T-case built to 7.3l diesel spec with pump.
• Chain bearings and case saver
• All drive shafts custom built by Adams Driveshaft, Las Vegas.
• Rear has 1350 U-joints
+ one extra spare t-case.
Suspension/brakes:
• Front diff - Eaton Truetrac with 4.88 gears all new joints, seals ,bearing
• Dutchman XHD D-fab 9 3.5” tubes 380 wall with 35 spline axles with super set 20 large bearings
• Daytona support
• Yukon nodular case 3.25 large bearings ,4.88 gears
• Yukon Grizzly locker
• Wilwood proportioning valve
• Motorsports stage 4 Kit with Uni ball King shocks. Rear spring perch and extended shackles with King bump stops on all corners. Steering updated to ambulance HD parts installed 3/2017 Stage 4 Long-Travel Suspension Kit / Bronco & F150 | Solo Motorsports
https://solomotorsports.com/shop/suspen ... it-bronco/
• All drive shafts custom built by Adams Driveshaft Inc
• Antiwrap by Ruff Stuff
• Explorer rear disc kit by Currie Cross drilled and slotted rotors all four wheels
• Reman calipers all 4 corners EBC pads
• All new bearings and sealer ball Joints
• The parking brakes work
NOTES:
Comes with extra parts: tailgate ,factory shifter, OEM console. Winter. OEM spare tire carrier. Spare mount for bed with tie down strap. New power lock actuators, latches, cables, handles. Handle repair kit. Dash brace upgrade. Ford OEM manuals and Cd set. Off-road jack and carrier. Clusters,PCM’s. Much more
Is register in NV as a classic rod. No smog
Has about 220k On registration
Trail cam & converter installed. Comes with Larger cam and lifters
50K open to negotiation
Steve G
702 544 2101 text
lvsteve@yahoo.com
Can email more photos and video
LvSteve
Re: 95 Bronco XLT
Post by LvSteve »
Update.
Now has Fresh 2 stage PPG paint with OEM color pack. first color sand and buff done . All door windows' moldings locks' latch's handles removed for paint . OEM Tailgate with weather strips installed Have body side molding but not reinstalled
Winter shifter removed and Oem shifter reinstalled. with center box.. Comes in oem shop manuals and ford cd set.
plus many extra parts
Motivated seller
LvSteve
Re: 95 Bronco XLT
Post by LvSteve »
[/attachment]
LvSteve
Re: 95 Bronco XLT
Post by LvSteve »
Re: 95 Bronco XLT
Badass rig! Good luck with the sale, Steve!
LvSteve
Re: 95 Bronco XLT
Post by LvSteve »
Bump . Priced dropped to 39K. Open to offer and trades NO UTV
LvSteve
Re: 95 Bronco XLT
Post by LvSteve »
Sold
