Cleaning out the garage - If you want ALL of it, I will make you one heck of a deal!
Complete front end- Threat stock width beams, plated, trussed, uni-ball pivots. Boxed radius arms and pivots. Solo beam pivots with hardware. Solo skid plate, Knuckles, axles, third member etc. from a 96 Bronco with the bolt on calipers. Includes the uni-balls and heims. All new, never mounted. $2000.00
Solo bolt on front shock hoops with crossbar. New, never mounted. $500.00
Solo tig welded pitman arm and swinger for single swing steering. (no tie rods). $200.00
NEW 14" King 2.5 coilovers with 450 over 500 springs. $1000.00 / pair
NEW Giant 64" link killer setup for a F150. Complete with hardware, never mounted. $1500.00
Used 18 x 2.5 race series King shocks good condition, no leaks. $500.00 / pair
Used Currie 9" rear end with disc brakes. This is the standard pre runner rear end with 3.25 fully trussed housing, 31 spline axles, 4:56 gears, detroit locker, skid plate, Low miles, excellent condition. Set-up for Bronco $1500.00 and I'll throw in the new Solo VSS relocator kit.
6 new, never mounted Kuhmo 35 12.50 15 mud terrains. $1000.00
Located in San Diego, (Alpine) 6 1 9 8 5 5 2 2 1 0.
LOTS of Bronco/F150 parts
- Bronco Info: 99 Explorer -Dixon Front, Giant 64 rear.
Re: LOTS of Bronco/F150 parts
Rear end is 65" wms. Not a floater rear end.
Rear end sold.
steering and 64 kit is sold.
Engine cage / shock hoop sold.
- Needles929
- Bronco Info: 95 Part Deux
Can you text me some pics of the beams and stuff? 480-463-0158
