Whats up guys got a bunch of parts for sale that I've gathered that I won't use came..
-Deaver F64s
-4 outlaw II wheels 5x5.5, 2 are drilled for 5/8 studs, have 35x12.5x15 good year wrangler Mts, 2 are 70% 2 are 50%
-tube front bumper weld on
-bilstein 2.65x14 coilovers with springs
-4" flare (I think) fiberglass front fenders for 92-96 bronco/f150
-passanger side door off 85 f150
-bolt in bed cage that came off 85 f150
-5 speed manual trans out of 85 f150
-manual transfer case out of 85 f150
-pro comp 4" or 6" drop brackets for 4wd bronco/f150
-4" drop pitman arm
-4" kartek poly bumps
-leaf spring bash plates with shock tabs welded on top
-custom engine cage for bronco/f150, cut off clean, holds 14" single coiler
-hood off 85 f150
-lights/grill off 93 f150
-stock steering linkage off 85 f150 4wd
-front and rear pro comp extended brake lines
-front and rear drive shaft out of 85 f150 4wd
please text Vincent for pics and prices of whatever you're looking for. located in Huntington Beach
Lots Of F150/Bronco Parts
- Bronco Info: 1992 Ford Bronco, just starting a prerunner build, planning on 2.5 coil overs up front, stock beams
Re: Lots Of F150/Bronco Parts
714-862-8160
also have a stock dana 44 third member
also have 302 stock y pipe with cats
bump make offers
Text me at(805) 746-5367 interested in the deavers.
Also the front fiberglass
Interested in engine cage text me 714 8816982
