Built 8.8
Built 8.8
I have a built 8.8 for sale. Decided To go another route. Came out of a 95 bronco. Has 4.56 gears and a Detroit locker. Also has a mag-hytec diff cover which has a little dipstick out the top. 5/8” wheels studs and a truss under the bottom and limit strap tabs off the back. The perches have been re-welded to eliminate the wedge blocks. It has maybe 400 miles on new gears/locker/rebuild. Everything is in great condition. Bolt it in, bleed the brakes, and drive off into the desert. Looking to get $1100.
Just a regear and a locker are more than that. Located in riverside. Text me (951)452-4050.
1Hondalover
Re: Built 8.8
Post by 1Hondalover »
Sorry I don't text buddy. If this was 4.11 it may be in my hands already. Did you fab the truss and degree the pads?
Built 8.8
All done by solo
Built 8.8
Bump. If you can’t use 5/8” studs you can always swap out your inner axles and keep the 5/8” stud axles for when you move up to the larger wheel studs.
Built 8.8
$900 without the rear cover.
Built 8.8
I also might have a set of 1/2” stud axles I can throw into the housing instead of the 5/8” studs.
Built 8.8
Bump
Built 8.8
Turns out this rear axle was fabricated by southwest. A bronco just came in that was built by southwest and it has the exact same truss and traction bar tabs.
Did this sell?
Sent from my SM-G950U using Tapatalk
Built 8.8
robertcrav wrote:Did this sell?
Yes I did. Sorry
