Solo Motorsports Stage 4 Suspension Kit
Posted: Wed Jan 24, 2018 12:30 pm
Brand new kit:
Specs
Front suspension travel approx.: 15 in
Rear suspension travel approx.: 17 in
Front and rear track width (wms to wms): stock
Front and rear suspension lift approx.: 4 in
Recommended tire size: 35 in
Fiberglass required: No
Kit Includes
Front
Set of 12″ 2.5 King Coilover shocks with hose remote (built specific for Ford Broncos or F-150s)
Dana 44 Cut N’ Turned TTB Beam Work *
1.25″ Heimed Extended Radius Arms with Pivot Brackets, Misalignment Spacers, & Grade 8 Hardware
3-Piece Extended Brake Line Kit for the front and rear
Alignment Cams
Dropped Pitman Arm
W-I-Y Coilover Conversion Shock Hoops
Rear
set of 12″ 2.5 King Remote Reservoir Smooth-Body shocks
Deaver Q80 Leaf Springs, U-Bolts, and Bushings (please call for F-150 options)
W-I-Y Under-the-Bed Shock Mounts (please call for F-150 options)
Q80 Shackle Conversion Kit
Extended Stainless Steel Brake Line
Changing directions a bit on my build. Brand new kit, shocks still in the plastic, never mocked up or installed. Looking to move this quickly.
$4750.00 OBO + shipping
Located in Houston, TX
Specs
Kit Includes
Front
Alignment Cams
Dropped Pitman Arm
Rear
