I have a set of fabricated shackles for a 3” wide spring. They are about an inch longer than stock to drop the rear a little. They will work with the stock hangers, no spacers needed unless you put in 2.5” wide aftermarket springs. Stock bronco springs are 3” wide. These are in very good condition and the bushing look new. Ended up making my own shackles. Located in riverside/Colton. Looking to get $100 for the pair.
Bronco Fabricated shackles
- Bronco Info: 1992 Ford Bronco, just starting a prerunner build, planning on 2.5 coil overs up front, stock beams
Re: Bronco Fabricated shackles
interested, text me 714-862-8160
Bump. Found out these are made by southwest.
- RyanDS650X
100 shipped to 85215 and I'm your buyer.
-shockseals.com
-shockseals.com
I can probably do that.
These shackles were made for a J40 spring to droop out on factory location hangers.
- RyanDS650X
Sweet how do you want payment?
-shockseals.com
-shockseals.com
What’s the ID of the area where the leaf spring bolts up?
- RyanDS650X
Soooo. We still doing this?
-shockseals.com
-shockseals.com
