ford 9 inch 68 wide van
posting for a friend was in a ranger has about 500 miles on third
ford van 9 inch 68 wide current set up is 3 link
5.83 gears
spool
equal length 31 spline axles
nodular case third
5/8 studs
drum brakes
one set of equal length strange 35 axles included that fit this set up for the rearend.
$800.00 if you do not want the 35 spine axles price will go down some.
Bronco 4x4 guys gears would have to be changed as 5.43 the most you can get for the Dana 44 front I believe. This is still a nice set up if you make the change from 8.8 and go wider.
I am working on pictures.
bmcduffie
Bronco Info: 95 bronco, under construction
Re: ford 9 inch 68 wide van
Post by bmcduffie »
Is this still available
Text me pics 909 915 7053
bmcduffie wrote:Is this still available
yes I get you pic
Sold
