Four tires have around 80% tread. One of them has a plug. Two have light chunking from spinning on the rear. One tire on spare, non-beadlock wheel has around 30% tread. One wheel is severely damaged on the inner bead from hitting a rock. Three of the beadlocks have flat spots on the inner bead from years of abuse; however, it's not noticeable in tire wear or driving. Pick up a fourth and continue beating on them. Drilled for 5/8 studs. They've been great wheels. Wheels are 15x8 3.75 backspacing. $600 Yucaipa, 92399. Will not separate.
(5) Toyo 35x13.5x15 on 4 Champion Beadlocks
Re: (5) Toyo 35x13.5x15 on 4 Champion Beadlocks
Still available.
