Fiberglass 4 pin hood was for my 1995 - $200
Raptor shocks. Rebuilt with new seals, fluid and schrader valves installed on resi's by DC Shock Services $400 obo
South Orange County area 92688
Work in Buena Park
Bronco parts
- rdcjuanb
Bronco parts
Re: Bronco parts
Can you use the factory mounting locations for the shocks or must an aftermarket relocation upper be installed? Just didnt know how much longer they are compared to the 5100's that I use (J40 springs in rear).
- rdcjuanb
Re: Bronco parts
They were mounted to an aftermarket mount.biggiek wrote:Can you use the factory mounting locations for the shocks or must an aftermarket relocation upper be installed? Just didnt know how much longer they are compared to the 5100's that I use (J40 springs in rear).
- Bronco Info: 1995 ford bronco
Re: Bronco parts
does the hood bolt to factory hinges? if so ill take it 805-302-581two
- CrazyBRONCOguy
- Bronco Info: 1992 and a 1978
Re: Bronco parts
Any interest in shipping the FOX shocks if bought at your asking price? As in 400+ shipping
Completely understandable if you would rather not mess with shipping stuff.
'92 Eddie Bauer- C6 Swap, 9" Swap, Roller 357W, AFR 165's, MAF, SCT Tuned, 4.10's
'78 Custom- 4" Deaver Lift, Mild 460, 8 Point Cage, 4.10's
- rdcjuanb
Re: Bronco parts
Shipping is fine.
Hood is a 4 pin so no hinge mounts.
- CrazyBRONCOguy
Re: Bronco parts
Sent a PM back. Thanks
- rdcjuanb
Re: Bronco parts
Shocks are gone. Hood still available
