Hello all,
For sale are a pair of 2.0 bumpstop mounts. They bolt on in the stock place where the coil buckets were at. So I built these and forgot to put the coils on during mockup- so at full droop on my setup the coils hit. Had I just moved the lower mount (which were done and welded in place) outward an inch it would have all been fine. I have 4.5" beams so if you have 4.5"+ beams (and not a dumbass while arranging the mounts these are genuinely a great part. These were done so the bumps are equal on both the driver and pass side literally at max compression. I'd like to get $125 for the pair. - shipping is $12. PayPal is u10072@hotmail.com - pay as a friend/ family - call/text anytime 6025028945
Thx,
Matt
2.0 Bumpstop Mounts
2.0 Bumpstop Mounts
Re: 2.0 Bumpstop Mounts
Smokin deal!
Someone needs some bumps!!
Still for sale- if you have 4.5" over beams and are building from scratch these allow max compression travel and will easily work if you account for them-- which my dumbass did not
Get ya bump stops here!
Still ready to ship these!
Ok someone make me a shipped offer (med flat rate )and get these gone! These will mount to factory holes, need a 4.5" over beam and need the coilovers to. R mounted farther out on the beam then I stupidly didn't do prior to welding and was told to do. Anyway I love these but won't fit my truck unfortunately!
