Hello All,
I have a 3 Bolt Delphi Conversion box that I am going to call a "Kit". Its a kit of sorts because it comes with the 3 turn box, the nice bullet nosed bolts which are about a 1/2" bolt, the input shaft coupler, the pitman arm and a fitting for the return line. Ww\hen I bought the box it first off had a reman stamp on it. I wire wheeled it as I was going to use it but ended up going with a 4-bolt box because I like spending hours fabbing parts for no real reason. The lower 2 bolt holes are literally in the exact same spot as the factory bronco mounting holes. With a hole saw or 2 (not a drill bit) - you should be able to install that upper hole really easily. I can even provide a random 12" length of tubing for the sleeve if you like. As far as the pitman arm goes-- the factory Ford unit appears to work perfectly in my opinion or use the GM unit for a fabbed pitman arm.
Selling the whole lot for $120 shipped to your door! - paypal is u10072@hotmail.com - gotta pay as a friend/family and I can ship it same day or next day at the latest! Call or text if you have any questions! 602.502.8945
Thanks,
Matt
Delphi Conversion Box "Kit"
Re: Delphi Conversion Box "Kit"
Pm sent
Bump it up folks!
