Floater 9" 40 spline
- baja-chris
Floater 9" 40 spline. 3" wider than stock full size bronco or 80-96 F150. Camburg 3.5" dia 4130 housing, trussed, with snouts for the 2.5" wide bearing Camburg hubs. 40 Spline CTM 300M axles. Housing is tabbed out for 3 link. $1500 price includes the housing and axles only. Chris 619-890-0284.
- baja-chris
Re: Floater 9" 40 spline
$2k with 3rd member, 4.88 spool.
Killer deal!!
Chris is this 3" over total width or 3" over per side?
- baja-chris
3" total, 1.5" per side. 68" WMS width.
4130 fabricated housing, tabbed out for bronco 3-link, wide bearing 2.5" snouts (fits Camburg 2.5" wide bearing hubs). 40 spline 300M axles. 3rd member with 4.88 and spool. Housing/axles/3rd, all for $2000.
This housing also has spring under leaf mounts and if you buy all the above I will give you the brand new spring under leafs and shackles that were designed for it. It cycled 24" on these leafs.
But we have given up on class 3 and made a new wider housing and run coilovers now and also upgraded the 3rd member to a 9.5" ring gear.
- RyanDS650X
- baja-chris
Sounds like the 3rd member is sold.
$1200 for the housing and axles...
The axles alone cost that much.
- baja-chris
3rd member sold
axles sold
housing now $500. way less than 1/3 the cost of new.
axles sold
- funinthesun95
Chris I call you tomorrow.
On this
On this
- baja-chris
housing, leafs, shackles SOLD
- rdcjuanb
Smoking deal on that housing.
- baja-chris
I'll be cleaning house over the next couple months and selling off more bronco parts (C6, front end stuff), and tools (welder, oxy torch, roll away w/tools, drill press, band saw, press, table sander, Vidmar parts drawer system, etc.)
Down sizing. PM if you have something specific you need. Going to sell the 4-seater too, boat trades considered on that.
I wish I wasn't moving!!
