Extended beams
steve-oh
Extended beams
Post by steve-oh »
4.5 over beams , cut and turn hasn't been done wasn't lifting truck much, located in central fl, have extended axles as well, take 500 for it all
steve-oh
Extended beams
Post by steve-oh »
steve-oh
Extended beams
Post by steve-oh »
Possible trades as well
eoffroader
Bronco Info: 1994 bronco 4.5 beams bilstein c/o behind the beam rad arms 456 front and rear f53 deavers blue inte
Re: Extended beams
Post by eoffroader »
If you were closer because I just bent my beams last weekend
rdcjuanb
Re: Extended beams
Post by rdcjuanb »
Bummer that shipping wouldn't make it worth it. They look good
Re: Extended beams
rdcjuanb wrote:Bummer that shipping wouldn't make it worth it. They look good
Is fasten all in Florida? I know you can pallet ship thru them for cheap...or grey hound.... just saying
Extended beams
Who did the work on the beams/axles?
steve-oh
Post by steve-oh »
I did all the work on the beams, mocked up axle in frame at ride height to check fitment, and had spoke with quite a few guys from here and other shops when I was doing them, wasn't as difficult as a lot of guys make it sound but it was time consuming for sure, I do have a fastenal right down the road from my shop, if your serious pm me and I'm sure we can work something out, these will probably just sit around here since there is no one around me using ttb at all
