Freshly built Saginaw P Pump with increased pressure and flow to work with a steering ram. This pump was built by Tommy Lee just before he closed up shop. I switched to a different style pump and never installed it. Comes with a new factory pulley and a custom pressure line that was used briefly on a factory pump. Will also include a new 6AN fitting for the steering box. $250 shipped
Tommy Lee Saginaw P Pump
Re: Tommy Lee Saginaw P Pump
Tempting since he never finished the one I ordered...
I thought they stopped making these......
Is this the one that bolts into the stock C2 pump bracket or is it a standard P-pump pattern?
Has the adapter and shaft to fit the factory cast aluminum bracket.cs_drums wrote:Is this the one that bolts into the stock C2 pump bracket or is it a standard P-pump pattern?
PM sent
Replied
So sad I missed this. Dibs if you decide to go a different route Damon1272.
