Class 3 Leaf Spring setup for linked rear end. 64" symetrical leafs setup for a dual shackle setup (shackle on each end of leafs).
Shackles included. This fits a full size bronco and the leafs fit under the frame rails and the leafs run under the rear end housing.
Can cycle up to 24" with properly designed links. The inboard leaf setup allows for room for 4" bypass shocks on the trailing arms.
The inboard setup allows allows for just the right amount of roll stiffness for a class 3. Still very controllable on the pavement with a spool.
But yields excellent traction and compliance off road. These leafs are BRAND NEW with zero miles on them.
$400 for the leafs and shackles with new bushings.
- baja-chris
Re: Class 3 Leaf Spring setup for linked rear end
Pics? I'm kinda confused on what this is
