rebuilt 8.8 with new 4.88s
I Have a 8.8 I built for my 96 bronco with new bearings and new motive 4.88 gears. I cut the perches and shock mounts off ( to ditch the factory wedge and run the solo mounts), brakes in ok condition. i have new perches I can weld back on at whatever pinion angle you want. not using now I ended up going 9" $550 located in anaheim
- Bronco Info: 1994 XLT 5.8 with a slightly above the Poverty Line set-up.
Re: rebuilt 8.8 with new 4.88s
INTERESTED, DM SENT
