89-96 smog stuff
- funinthesun95
89-96 smog stuff
I have tons of smog stuff for f150 f250 and broncos if anyone needs anything.
- Andy Jones
- Bronco Info: In the Works!
89-96 smog stuff
Do you have that coffee can dealio?!
89-96 smog stuff
The coffee can thing is the vacuum canister. Not sure if it’s smog related as it just holds extra vacuum. The later broncos(95-96) have a big plastic vacuum tank while the earlier ones have like a coffee can.Andy Jones wrote:Do you have that coffee can dealio?!
- Andy Jones
89-96 smog stuff
Copy that Travis! Mines a 95.Tchajagos wrote:The coffee can thing is the vacuum canister. Not sure if it’s smog related as it just holds extra vacuum. The later broncos(95-96) have a big plastic vacuum tank while the earlier ones have like a coffee can.Andy Jones wrote:Do you have that coffee can dealio?!
Re: 89-96 smog stuff
stock air filter housing? Thats the only thing ive been bitched at when getting a smog and I tossed that long ago.
- funinthesun95
I do
- funinthesun95
are you MAF or not?shockseals.com wrote:stock air filter housing? Thats the only thing ive been bitched at when getting a smog and I tossed that long ago.
- funinthesun95
I have both I think
- funinthesun95
just put a K@N part number sticker and tell them the filter C.A.R.B legal the housing should not matter.... it probably dose tho.shockseals.com wrote:stock air filter housing? Thats the only thing ive been bitched at when getting a smog and I tossed that long ago.
- Bronco Info: 1995 5.0, 5spd, C&T trussed beams, 14" kings, Q80's with 12" king triples, trussed 9" w/4.56
Do you have a smog pump for a 95 5.0?
