86 bronco master cylinder
FUFIMI
Post by FUFIMI »
I have a remanufactored brake master cylinder from orielys. The only thing that it does not have is the cap for the master. It was never run, only bought it to use the cap and was going to put it on but sold the bronco before I used it. So if you need it just let me know and it is yours.
Autofabtimmy
Bronco Info: 87 4x4 4.9
Re: 86 bronco master cylinder
Post by Autofabtimmy »
need need and double need this.
FUFIMI
Post by FUFIMI »
It is yours then. You are in San Diego, right?
Autofabtimmy
i am indeed. will this work on my 88
FUFIMI
Post by FUFIMI »
No I think the 88 is different. Sorry, the one I have looks like this:Image
Timmy - if his doesn't work I've got this off an '87 I parted. Maybe it will work?
I have it listed here for $35. Gimme $10 + shipping or pick it up & it's yours. Might be able to get a parts train going to get it down to you or sent it out to the LeDuc swap meet with someone if you're gonna go to that.
Autofabtimmy
awesome thanks i put some bumpers on it and wanted to drive it around and the radiator cracked so i just threw that in i cant wait to beable to stop
cwrisley
Post by cwrisley »
Do the F350 conversion! You wont regret it.
Autofabtimmy
details buddy is it just the master and the booster or do i run the calipers and different lines keep in mind this is supposed to be a stock work truck... with coilovers and 35s and a whole bunch of autofab parts ahahahaha
Master & booster I believe is all. A bit of searching (use google & search the website name & F350 master) should pull up some info.
Autofabtimmy
sorry for stealing your post remanufatured brake cylinder still up for grabs ahahaha
FUFIMI
Post by FUFIMI »
It's alright man, thanks
