Mild DD 1982 F150 flareside build
Built an under the bed shock mount.
I just hope the shocks are not leaned too far forward at bump. Definitely going to need bypasses.
Wheels came in off of amazon. Sometimes you can find some pretty incredible deals.
Also ordered a 38 gallon rear tank. Better than a bronco tank because it doesn’t hang as low and it has more capacity. It was like $85 off eBay with a 10 year warranty (USA seller) and the kit to lengthen the fuel pump pickup tubes.
I’m more than likely going to make a fuel tank skid plate. Didn’t really like the straps with the long spacers.
Making some solid body bushings at work out of aluminum. Eventually I want to put in a cage.
Also some solid motor mounts.
As you can clearly see, this thing has snowballed out of control.
Re: Mild DD 1982 F150 flareside build
Don't they always??? Liking the progress and parts.
Finally finished the engine cage/upper shock mints. For some reason the 82 F150 frame was like 1” narrower than later years or something. The cross over tube wouldn’t fit so I had to make a new one. Also replaced the flanges with inline clamps and then painted everything. Next will be installing the solid motor mounts.
Pickuptrucker
Post by Pickuptrucker »
Sweet keep it up
Goals for the weekend.
-replace all freeze plugs with brass
-install solid motor mounts
-install headers
-clean throttle body
-install wiring harnesses
-mount a/c box
-mount core support
-mount steering box brace
-front break lines
Yes I’m going to run factory abs out of a 95 bronco. It will be on a switch to turn it off when offroad.
Aluminum body mount bushings.
