Page 16 of 23
Re: 95 F150 - Project Marilyn
Posted: Wed Aug 02, 2017 5:36 pm
by VintageIronFab
Jump seats are in. So much more room for activities!!
Posted: Thu Aug 03, 2017 10:01 am
by ChaseTruck754
VintageIronFab wrote:That's actual Linex- I have the parts Sandblasted to basically etch them and get the surface ready. I figure if they can spray wood with it then janky plastic will be fine lol!
Got it. When you hd said it blends with the Line-X bed pretty well I was thinking it must be another product.
They can spray that stuff over most anything!
Posted: Sat Aug 05, 2017 7:05 am
by VintageIronFab
My custom 3 point harnesses- no miles on them but the idea is keep you planted in the seat and still be able to run errands lol. It's gonna be an awesome idea or a terrible one - only time/miles will tell!
Posted: Sat Aug 05, 2017 7:14 am
by VintageIronFab
All the factory mounting points were retained along with how the factory belts secure to the body were used.
Posted: Tue Aug 15, 2017 10:39 pm
by VintageIronFab
My raptor inspired grill lights--
Posted: Wed Aug 16, 2017 8:30 am
by biggiek
I have been wanting to do this. Link for the lights?
Posted: Wed Aug 16, 2017 11:49 am
by VintageIronFab
I bought them local at a place that sells every light known to man --they are like wayyyyy overpriced lol but I still sprung for them. I think they were like $16 each with the light and the little metal surround- mine are black but they are normally chrome. The little surround is pretty clever and mounts pretty easy. I guess hit me up and I can get you a set.
Posted: Thu Aug 17, 2017 10:20 pm
by VintageIronFab
After literally 2 solid months of abject vehicular torture... I went with my last "nuclear" option! I'm just praying this works! Out with the Lightning and in with the Terminator!
Posted: Mon Aug 21, 2017 5:35 pm
by VintageIronFab
If you ever decide to change your type of injection, add an adjustable fuel pressure regulator, are pulling an engine and mangle a fuel line or maybe burn one up-- one easy and fairly cheap fix is to remove the lines around the fuel pump forward to the engine; cut them at the flex line/hardline area; slide on a tube nut then tube sleeve; then single 37* flare the 5/16" line (on my 95 F150 BOTH lines are this size) then finally add a male/male -5AN/-6AN fitting. After that you just connect to the engine in the configuration you need. Some would ask why not go all the way -6AN. Well it depends whether you need that much fuel volume, and it allows you to retain a factory stainless steel line, fuel filter and fuel pump connection at the tank.
Posted: Mon Sep 04, 2017 4:57 pm
by VintageIronFab
So close I can smell the carbon monoxide!!
Posted: Mon Sep 04, 2017 5:42 pm
by VintageIronFab
So I need a vote of sorts- do I rock the classic 14" air cleaner or the air intake tube that a common on the later models??
Posted: Tue Sep 05, 2017 4:07 pm
by zachwabbit
I like the look of the classic center mounted air cleaner, but I read somewhere that the factory air boxes are hard to beat for sand/silt filtration, only thing better is an UMP setup. I think it was someone on here who told me that lol
Posted: Sun Sep 24, 2017 7:35 am
by VintageIronFab
Now that I've got a throttle body vs SEFI on the engine there's a fairly large hole to contend with. Here's my fix that was fast, easy and required no welding wire lol!
Posted: Sat Oct 07, 2017 7:18 pm
by VintageIronFab
Some pics of the radius arm crossmember. This isn't a crawler so hopefully it doesn't get ripped the hell off! Basically 1 3/4" x .250 wall tubing was the material.
Posted: Sat Oct 07, 2017 7:25 pm
by VintageIronFab
Few pics of my quick release fire extinguisher mount- gotta love that ozone friendly Halon 1211. Didn't want the gear clamp mechanism showing. The extra hole is for a padlock- if you're in downtown Phoenix or Ensenada I don't need it disappearing
Posted: Mon Oct 09, 2017 9:52 am
by toddz69
When's this thing going to be on the road???
Posted: Tue Nov 28, 2017 6:31 pm
by VintageIronFab
Now that I’m finalky back in Phoenix and released from the dastardly clutches of the Midwest lol...Marilyn is finally getting an alignment! The local Firestone fellas probably haven’t seen a 4.5” over swingset steering truck.... maybe ever!
Posted: Wed Nov 29, 2017 2:57 pm
by Needles929
When and where are you taking it out to play??!!
Posted: Thu Nov 30, 2017 12:29 pm
by zachwabbit
So much want!
Posted: Thu Nov 30, 2017 9:46 pm
by VintageIronFab
Well just an update- I’ve taken this truck to 2 places - first place the front end was too wide for the machine; the second place is just honestly being chumps and not willing to do the work. Reason #1892 to not go wider!
If I cat get the engine tuned and the trans controller to work right. It’s a super killer truck but it’s really (and I mean really) testing my resolve.
