I am very self taught. I read a lot and looked at pictures. I still don't think I can weld when CHO post pictures of his work.dtbback wrote:otter wrote:Thanks man. I wish I had someone teach me. I actually have seen anyone else weld except for me. Lots of trial and error and frustration.dtbback wrote:Some seriously beautiful beads!!
Thanks, It is a huge improvement. You should get some.nubreed71 wrote:Truck looks killer! I'm definitely jealous of that single swing steering...
Your self taught!!! Now I'm really impressed and a little jealous! Your welds are seriously beautiful!
1994 F150 (The wife made me do it)
- otter
Re: 1994 F150 (The wife made me do it)
Yeah his work is on another level but yours is nothing to scoff at.
Funny, I think the same thing!otter wrote: still don't think I can weld when CHO post pictures of his work.
I will say your MIG beads posted above blow mine away. I hate my MIG beads so I never use the thing & that just continues the cycle.
- Bronco Info: Ford F150 Flareside
Truck looks awesome, really digging the steering. Definitely on the upgrade list for my rig one of these days.
- otter
Thanks man. Yours is looking pretty freaking good also.jkrell wrote:Truck looks awesome, really digging the steering. Definitely on the upgrade list for my rig one of these days.
Those are some good looking bumps!
- otter
They really are. Except for the issues with the bypasses I am pretty happy with the quality of the FOA'sdtbback wrote:Those are some good looking bumps!
What were the issues with your bypasses? I just bought the 14" version for my underbed set up and I think some oil was leaking out of one of the bypass tubes. The bypass valves are all the way open. But I hoping they aren't leaking.
- otter
They messed up the machining on the pistons. The groove that the wear band sits in was not deep enough.
Ahh ok. How did you figure that out?
- otter
I had to use an engine hoist to extend them!dtbback wrote:Ahh ok. How did you figure that out?
Hahaha. The used pair I picked up have their firm valving stack in them. We had to mount them in a vise to extend them. Then then they seemed to pull in phases. That's due to the bypass tubes, right?
- otter
I was told they use a brass wear band and it hangs up on the tubes where they were welded.
So it needs to groove itself as the shocks break in?otter wrote:I was told they use a brass wear band and it hangs up on the tubes where they were welded.
- otter
I guess that is what they were implying.
Seems odd they wouldn't run a ball hone or roller burnished through the shock body post welding. Reguardless of wear band material, a burr is a burr and they need to be smoothed. I'd call and ask if there's and post welding machining process like honing or something.
- otter
I was also thinking the same thing. We will see when I get them back. I am just ready to get them on the truck.
Let me know what they say. If need be I'll send the pair I have back to get them honed.
You would think they would hone the inside of ther cylinder post tube welding. I hope that's the case.Rmc wrote:Seems odd they wouldn't run a ball hone or roller burnished through the shock body post welding. Reguardless of wear band material, a burr is a burr and they need to be smoothed. I'd call and ask if there's and post welding machining process like honing or something.
