My VERY mild DD
Re: My VERY mild DD
I bought some trailer deck tie downs that fold flush and a 3-point ratchet strap, had the bed floor cut and then the tie downs welded into the floor by Travis. Makes it so that when I'm camping and have the shell on I can take the spare out and lay an air mattress in the bed without anything stabbing me in the back. Also had it done this way because I don't typically have the shell on for extended periods so didn't want to rely on a rack on top of the shell to hold it.
Potato.
- Bronco Info: It's a non Bronc! the bronco's larger cousin with a bed, a 95 f1
Re: My VERY mild DD
Hey guys! Curious for anyone who has run or is running a stock width truck with stock inner fender liners and 35” BFGs, what bumps do you use? I’m planning to just replace the factory bumps with poly or aftermarket rubber, but I’d rather not tear it apart and cycle it haha ( call me lazy) just a reminder, the truck is running 3” rancho drop brackets and radius arms, 4” procomp single cab coils, and 5100s on factory Alcoa’s and 35” ko1s, which I feel like is a pretty similar setup to what a lot of guys start with. Thanks I’m advance!
Also, anyone have some decently clean bronco dual shock buckets they want to part with?
My VERY mild DD
When I set up air bumps on the fronts of cut/turn beams I set the beams up to be 2-5/8” from the frame. Allows the perfect amount to run 35” tires without rubbing. If you want to dial it in you can take your coil out and jack up the beam with the tire on and measure frame distance.
