1997 f250 prerunner build
- offrdmania
- Bronco Info: 1997 F350. Same frontend as a Bronco, does that count?
Re: Go Fast ( presented in f250 HD)
I was actually digging the fender eyebrows. It gave it the period flare
- Bronco Info: sold 94 (wanna bronco on FSB) 1997 f250 hd
bajascott wrote:looks good!
thanks dude!
- RyanDS650X
Bitchin! Great job.
-shockseals.com
-shockseals.com
thanks dude! its been a lot of work, mostly by myself. considering i live in KC now most of these farm boys have no interest in what i got going onRyanDS650X wrote:Bitchin! Great job.
where do you guys put limit straps on the rear end for your progressive leaf pack? basically the rear end rebounds WAY up after landing, i assume i can remedy that by strapping it. should i weld to the axle tubes and hook to frame? or just get a real long strap and go around the axle tubes and "basket" it back up to the frame, that seems way stronger and i don't have to weld to the axle tubes....
I was going to weld mine to the top of the spring plate.
The limit strap is used to keep your suspension from over-extending and damaging shocks and maybe driveshaft (due to joints binding). What you're feeling is a problem with shock valving.jimmyd wrote:basically the rear end rebounds WAY up after landing, i assume i can remedy that by strapping it.
SteveG wrote:The limit strap is used to keep your suspension from over-extending and damaging shocks and maybe driveshaft (due to joints binding). What you're feeling is a problem with shock valving.jimmyd wrote:basically the rear end rebounds WAY up after landing, i assume i can remedy that by strapping it.
well thats what i am afraid is happening when the rear end is hopping . i have adjustable shocks, and still can't find the right spot
so should i run bigger shocks? i am running rancho rs9000 adjustables (couldn't get anyhting else for at least 2 weeks when i purchased them, wanted bilsteins) in the stock mounts. should i just go through the bed? the front is awesome works perfect, but the back bounces way up when i "land".SteveG wrote:The limit strap is used to keep your suspension from over-extending and damaging shocks and maybe driveshaft (due to joints binding). What you're feeling is a problem with shock valving.jimmyd wrote:basically the rear end rebounds WAY up after landing, i assume i can remedy that by strapping it.
What do you have for rear springs? An overload will cause that kick that you have happening.
A progressive leaf pack.philofab wrote:What do you have for rear springs? An overload will cause that kick that you have happening.
what kind?
All leaf packs have progressive spring rates.jimmyd wrote:A progressive leaf pack.philofab wrote:What do you have for rear springs? An overload will cause that kick that you have happening.
The reason I ask is if the rear spring rate or the compression on the shock is set to high, it will cause it to "kick" or "bounce" after a good bump or hit. Sometimes the shock needs to have some compression removed to alleviate the problem, or some spring rate would need to be removed.
local shop built them for me.
its a 10 leaf pack with really thin leaves for each. i was thinking of removing a leaf but the guy who built them pointed out that if you remove one leaf from the series its going to throw off the whole bunch.
other than turning a dial on the rancho's, i can't do anything for the valving on my shocks and i currently have it set really soft, however not much difference at the hard setting either. i don't like these shocks.
either way, i know what i need to do now.
If your springs are new they will need to be broken in. Do they have some sort of friction remover between the leaves?
If those shocks are longer than stock in the stock mounts they could be bottoming the shocks before you use much of your travel. That will make it kick up too. Figure out a way to see how much travel you are using to narrow down what to work on. Im sure it would be easy to get volunteers to flog it through some bumps while you stand by the side and watch. Okay maybe that last one isnt such a good idea!
