Yup another Philofab Project... 1971 Ford F100
Re: Yup another Philofab Project... 1971 Ford F100
Looking forward to seeing what you do!
- johncharlesb
I think those frame rails are the old SAE 34". A Bronco II tank might work. A lot of folks put in 1970 Mustang 22 gal tanks. Dodge may still run that spacing.philofab wrote:I measured the rear frame rails for a modern fuel tank and they are a bit narrower than newer trucks (29" vs 32"). I may still try and squeeze a 90s Ford Bronco tank in there. 33 gallons of capacity would be nice. If not I'll build a tank that fits the dimensions of the rear frame or have a tank builder in Havasu do it.
http://www.fordification.com/forum/view ... =7&t=46022
Thanks for the link, I'm not sure if I want the filler in the center of the bed. I was really hoping for a 20mpg truck with a 500+ mile range (get to California and back without fuel).
I'll look into oversized Bronco II tanks.
http://www.polyperformance.com/shop/Jaz ... 20294.html
This might be an option too, except for the filler. There may be enough room if I flatten some 2" tubing for the fill and sandwich it between the cell and floor.
- johncharlesb
That is a nice tank.
Camper Specials had side mounted tanks. I doubt they are what you are looking for, but just letting you know they exist. I will be interested in what you come up with as the 62 has the same issue.
Anyone know if 68-69 drum brake beams are different? I know the spindles are but the extra beams would be nice to modify without taking the truck apart.
Picked up some wheels in Vegas yesterday. No luck on a motor yet.
These will be converted into bead locks. The offset will allow me to keep the truck low on the big tires. They are factory on 02+ Dodge Ram 1500s. 17" Diameter, 5x5.5, and I got the set for $60.
Looks like the beams have the same casting numbers.... they are drum brake beams on the truck so someone swapped disk spindles/knuckles on them. I've got a factory 3.50LS 9" center here I may run or I might just recycle the 9" out of my Bronco on this truck. A late model 9" is wider so not sure on clearance.
Not entirely sure what I want for gearing. 3.50 might feel ok, 3.73 or 4.11 might be better. No OD or lockup and I don't want it screaming at 80mph.
Yes beams should be the same - just the spindles/uprights are different (how much different I'm not sure) so as you said - swap on some disk spindles & go!
I asked about beams today, and apparently there are many different versions. The best have 1" king pins and were found in SOME 1 tons. Nothing is consistent, and there are even 3 different 1" versions, with the heaviest being the best. Most are 7/8".philofab wrote:Anyone know if 68-69 drum brake beams are different? I know the spindles are but the extra beams would be nice to modify without taking the truck apart.
This about sums up what I300 wrote:[Nothing is consistent
I've seen from the 60's/70's Fords.
If you want a run down on beams/kingpins give me a call. I figured you knew a bunch already so I didn't add much to my post above.
Picked up some crappy old shocks off of CL for the front. 14x2.5s with a 350/450 rate. I've got to rebuild and clean them.
I kind of want this truck to be pretty so don't be surprised if it ends up with new Bilstein shocks before it's done.
- Joxracing
those are crappy?
Psh....
Psh....
Got some parts from Ruff Stuff Specialties today.
LS motor mounts and two shock mount buckets.
I started cleaning the bed out and was pleasantly surprised to it's condition. The inside is in very good shape, the tailgate even works well. I still need to pressure wash it out then start stripping the paint but I doubt I'll find any filler in there. I also started pulling the nasty interior out. All of it is glued with 3M spray adhesive so it's should be fun sanding / stripping all that off. I need to get the seat and the fuel tank out too. I'm worried about what I will find underneath the dash.
I also think I will build one piece side windows for this. I've never been a fan of vent windows and I've built 1pc stuff for 67-72 Chevy's before. I also installed a no-limit kit into a 49 Chevy pickup but it was just as much work as building my own. Has anyone done this on a 67-72 before? I'd like to keep the manual cranks but I'll go power if I have to.
Turbo 400 with fixed yoke and medium duty straight cut gears. Built with 0 miles on it.
That bed looks GOOD!philofab wrote:I started cleaning the bed out and was pleasantly surprised to it's condition. The inside is in very good shape, the tailgate even works well. I still need to pressure wash it out then start stripping the paint but I doubt I'll find any filler in there. I also started pulling the nasty interior out. All of it is glued with 3M spray adhesive so it's should be fun sanding / stripping all that off. I need to get the seat and the fuel tank out too. I'm worried about what I will find underneath the dash.
What are you worried about with the dash? Crap under that low-rider type velvet stuff or what?
As for the solid windows - keep us posted on what you do. I've heard a few guys talk about doing it on the 73-79 trucks but can't remember if anyone has ever done it.
I would think a google search for the topic using ford-trucks.com as the reference site. I'll see if I can dig anything up on this too...
I'm worried about what the dash looks like under that upholstery. I can feel one spot in the center that seems like it's caved in.ChaseTruck754 wrote:That bed looks GOOD!
The one piece windows will want to run into the hinges. It can be done but will require a bit of work and a filler panel at the front of the window.
Nice. I've been tempted to use those c/o mounts on various projects. Will you weld them on or make them bolt-on?philofab wrote:
I'm going to weld them to plates so they bolt on and add a cross bar. I wish they were a couple inches taller. At 12" above the frame rail they are too short for anything other than a 14" SAW or 14" short body Bilstein.SteveG wrote:Nice. I've been tempted to use those c/o mounts on various projects. Will you weld them on or make them bolt-on?
The plate will wrap around the frame rail to allow a limit strap mount and bump stop if needed. One of the nice things about rear steer is I have tons of room in front of the beam for a mount with no clearance issues.
[quote="philofab"I'm going to weld them to plates so they bolt on and add a cross bar. I wish they were a couple inches taller. At 12" above the frame rail they are too short for anything other than a 14" SAW or 14" short body Bilstein.[/quote]
You should bring this up to Dan. My guess is he would re-works the files about to cut/make a set a few inches taller if he knew they were something people could use.
