Hello All-
So on my F-150 I’ve got a great problem! So I’ve not put a set of bumpstops on the rear end and the rear end easily crashes into the frame. I’m thinking about a frame notch but I’m not thinking about a full rear bed cage. I do have 64” rear springs not a 4 link so diabolically weakening the frame is no bueno. If a rear cage on a truck is a must on rear go fast leaf sprung truck then I’ll just leave it alone for the time being.
Thx for the thoughts!
F160 Frame Notching???
Re: F160 Frame Notching???
Everyone will have their own opinion here but I personally wouldn't notch a rear frame like that without a cage or bedcage that has tubes landing on either side of the notch to give some reinforcement, as well as a tube that lands directly on top of the notch if the bumpstop is on this location. The tubes from the cage/bedcage don't need to be right at the notch, but there needs to be a bit of the truss structure that the cage would create so as to keep the frame from bending at the notch.
I see a lot of lowriders, etc. do the huge notches and box things in which may hold just fin for them, but they aren't slamming on the bumpstops like us.
- Becks_Bronco
Are you running bypasses? More oomph in the last section of travel, or hydro bumps? Wouldn't that be the less invasive/expensive route?
- funinthesun95
Make sure the 64 pack likes or is allowed to arch to the point you are thinking of allowing it. Some leaf packs like it others don't ( based on type and build set up) so your better off limiting reverse arch based on that info to help performance.
