Underhood plumbing
Underhood plumbing
I was wondering what everyone was doing with their smog equipment and vacuum canisters? My previous bronco included many zip ties and thats not going to fly this time. I'd like to keep things under the hood this time better organized and for the record I am horrible with organization.
Re: Underhood plumbing
Look at the 96 trucks - much much simplified
Underhood plumbing
I'm sorry I should explain better. How are people relocating the canisters fuse boxes and such that have to be moved to an engine cage? Some underhood shots of where people found spots for all the stuff that comes off the inner fenders.
- Becks_Bronco
Paying attention to this as well.
If you relocate the battery, and swap to a vintage air type HVAC system, you gain tremendous amounts of space in the engine bay. Re-routing or eliminating some of the vacuum mess only helps even more.
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Subbed for some future information
- RyanDS650X
Underhood plumbing
Kritters build thread has some pics of how he moved stuff around. Maybe he’ll chime in.hobbyturnedobsession wrote:I'm sorry I should explain better. How are people relocating the canisters fuse boxes and such that have to be moved to an engine cage? Some underhood shots of where people found spots for all the stuff that comes off the inner fenders.
here is how i did mine. let me know you want more pictures
http://www.gofastbroncos.com/forum/sear ... 7&sr=posts
ignore that one since this place wont let me edit post which is lame.
here is the right link
http://www.gofastbroncos.com/forum/view ... 46#p149925
Thank you sir. I was thinking the same way. Make a mount for the fuse box and rotate the canister sideways. What did you end up doing with the smog pump breather chingus that has the hoses attached to it on the passenger side?mobil1syn wrote:ignore that one since this place wont let me edit post which is lame.
Shoot I must have missed it. I'll look again thank you Ryan.RyanDS650X wrote:Kritters build thread has some pics of how he moved stuff around. Maybe he’ll chime in.hobbyturnedobsession wrote:I'm sorry I should explain better. How are people relocating the canisters fuse boxes and such that have to be moved to an engine cage? Some underhood shots of where people found spots for all the stuff that comes off the inner fenders.
i dont have a smog pump, but this is how a buddy with a speed density motor did his. his bronco came with the battery relocated and used that area to mount everythinghobbyturnedobsession wrote:Thank you sir. I was thinking the same way. Make a mount for the fuse box and rotate the canister sideways. What did you end up doing with the smog pump breather chingus that has the hoses attached to it on the passenger side?
- 201803249 (1).jpg (109.2 KiB) Viewed 2209 times
- 201803249 (2).jpg (61.43 KiB) Viewed 2209 times
- 20180324_.jpg (96.04 KiB) Viewed 2209 times
- 20180324_ (1).jpg (125.33 KiB) Viewed 2209 times
- Message_1.jpg (101.68 KiB) Viewed 2209 times
- Message_1 (1).jpg (81.06 KiB) Viewed 2209 times
he also reused the inner fender well. the drive is needed, the passenger side does nothing because the last time i was out with him it self ejected.
- 201803249.jpg (131.58 KiB) Viewed 2209 times
Underhood plumbing
Thank you! I've been considering reusing them. I'm not sure a 35" would clear.
- Bronco Info: 1985 Bronco Victorian 2 tone blue stock at the moment
Trash can!! lol
Hey it'll work!ThrustMaster wrote:Trash can!! lol
