Drive parts, what brands?
Dust
Post by Dust »
Just Curiosity 8-) What holds up the best, runs the smoothest, quietest, takes abuse etc...
Ring and Pinion:
Bearings:
Axle shafts:
U-joints:
Housings:
Re: Drive parts, what brands?
Dust wrote:Just Curiosity 8-) What holds up the best, runs the smoothest, quietest, takes abuse etc...
Ring and Pinion:
Bearings:
Axle shafts:
U-joints:
Housings:
U-joints: Get the spicer or Neapco without the zerk. The constant loading and unloading causes u-joints to snap where the zerk goes in.
Bearings: I've had bad luck with everything except Timken
Shafts: Any aftermarket seems to be great. Currie, moser, dutchman, ect.
Housings: Best bang for the buck is Ruff stuff.
Bearing retainers: The only ones that don't deform are Currie 1/4 thick ones. Don't use the drop in style, I bent a set like a pretzel in two weeks!
300
Post by 300 »
As far as ring and pinions, I have used both Richmond and Sierra Gear. Sierra is sold by West Coast Differential and I am sure others and is a little cheaper than Richmond, but appears to be as reliable. My gear shop confirms this. We have probably used one or two a year for the last ten years, most taken out by broken spider gears.
Prerunbronc
Bronco Info: 95 bronco 5.8 coilovers, deavers, 2.5 fox, full glass, air bumps, 9" rearend
Post by Prerunbronc »
Shafts I use currie
Gears I use motive
Dust
Post by Dust »
R&P: Spicer, then everything else with the Yukon being a noisy last.
U-joints: Spicer, then everything else.
Shafts: I have a supply of Yukon CrMo and have had no failures but...
B-joints: Blue Top Spicer, made by?
Bearings: Timkin
Oil: Amsoil
Housings... On my stuff Dana and Ford.
Rednek Renegade
Post by Rednek Renegade »
gears: I only use ford racing & yukon....no luck with richmond or genuine gear
Project el cheap-o
