8.8 TTB
Re: 8.8 TTB
Cycled and welded. With a little work the beam still hits the frame.
Had to grind on the P-side now D-side beam mount to make everything clear.
On to the front which will not be so easy.
Re: 8.8 TTB
Re: 8.8 TTB
Pics seem to be showing up this time. Nice to see some progress
Re: 8.8 TTB
How much of the beam is left where the diff mounts?
Re: 8.8 TTB
SteveG wrote:How much of the beam is left where the diff mounts?
None. The OX locker diff covers are weldable. I cut the center of the beam out and welded the diff cover in it's place. I will add a couple gussets from the cover to the remaining beam pieces in case my welds aren't the greatest........
So far I can pick the completely assembled beam up and carry it around pretty easily. Try that with a D44 beam.
So far I think it's about 45#'s lighter between the diff/spindles/brakes.
Re: 8.8 TTB
Lets see if this works.
Re: 8.8 TTB
Did for me.
