Hello All,
Has anyone used the 3-bolt Delphi steering box that came in the later model Chevy Tahoe and Cadillac Escalade ?? Seems like a much more modern design and if the install is easy should be a great upgrade. Just thinking about using that on my F150 project.
Thanks,
Matt
Saginaw 3-Bolt Steering Box- Anyone Use???
Re: Saginaw 3-Bolt Steering Box- Anyone Use???
I'm planning on giving it a try.... but have not done it yet.
I'd it bolt in replacement? What is better about it?
Not bolt in. You have to redo some mounting holes and sleeve them.
I run a 4 bolt one off an early 80's Ford Econoline.
I guess I was thinking the holes are really close to fitting?
Anyone know what the input shaft size is for these boxes ??
