On my Bronco I want to put two of those with shroud's and puller fans.
If I can afford it I will get a pair of Fluidyne Enduro Trans cooler with shrouds and fans but at $500 each is a bit high.
I may break down and do it anyway.
Transmission coolers
- Bronco Info: Mercury Mountaineer
Wrightracing.net wrote:Tru-Cool # LPD4739, 40,000 GVW rating, 45,000 BTU ratingrobertcrav wrote:Do you have pics/part numbers for that cooler?Wrightracing.net wrote:I agree with the statement that the puller fan is better than a pusher. The cooler in that picture did not work that well in the sand dunes at Glamis. I pulled it and put a True Line 45,000 GVW Trans cooler without a fan and it works so much better. The trans does not go above 180° anymore, even on hot days with a heavy load.
8 1/2 x 22 3/4 x 1 1/4 inch
Old thread I know but I settled on trying this cooler. Did you end up using the thermal bypass thermostat thing? I was thinking it might be nice for those winter trips when it gets down to 15* in the desert at night.
Re: Transmission coolers
not cold enough in baja or so cal - just for co or colder
Like Paul said, never used the bypass, in my mind it was just something else to fail. We try to keep things simple. Also the cold it not a issue in the desert. I love it that it runs at 150deg almost year around with a top temp of 190 in deep sand and silt for long periods.
On my 96 the gauge hit 140F by the time I got to the PMEX = 1 mile --- in january
Cool thanks, a friend also mentioned to me that it's another potential failure point, I just wanted to see what people who have been doing this for a lot longer thought.
- pat_car22
- Bronco Info: 1995 Bronco XLT 5.0-
I am looking to plumb my coolers this next week, I upgrader the core support and went with a CBR radiator without the trans cooler built in. So without this running through the radiator, I decided to go with twin external aluminum coolers with puller fans and shrouds. I am looking for info on the stock E40D hose ports sizes from the trans. Anyone have this info? [img][67745917882__23E33B6C-F08C-4383-89D6-DAA38363704D.HEICimg]
