Power Steering Pump Upgrades/Coolers
- Bronco Info: 1990 Bronco EB
My last Trip to Barstow has my stock Pump Bleeding in the driveway, I know that some Have done a Lee setup and a couple other brands.
What are the benifits of the Lee and othe aftermarket setups and what are the costs involved?
My stock pump has given me years of service without issue, that is untill i got it hot and probably boiled it over.
The second part is coolers, I was out this weekend and a guy had a huge Cooler and fan hooked up to his power steering.
I dont really see the need for it other than extending the life of the pump while bashing for hours on end.
Last is fluid, some people swear on Type F for the fords and some people use the clear Power steering fluid, what works best for what we do?
Thanks
Thanks
Re: Power Steering Pump Upgrades/Coolers
I run regular ATF in my pumps.
I upgraded to a Cardone sag pump with the factory cooler and have not had problems since. No more whine and no more fade in silt and sand.
- flyinbronco
- HuckMASTER
I have a Howe box but I run a stock replacement from Napa for the pump. I used a 6" x 12" trans cooler to keep the regular clear power steering fluid cool. You'd be suprised at how hot the fluid gets off road.
Type F !!??!! My understanding is that type F has friction material in it. For that reason I'd stay as far away from it as possible. DEX3 and Mercon no problem.
Oh forgot to mention filtration. A filter adds volume and catches all the nasty thats made from beating on the box. The volume will help with temps to some extent and getting rid of contaminents will extend the life of any system exponetially.
I have yet to install any of this on my 96 but the theory is the same on any vehicle.
philofab wrote:I run regular ATF in my pumps.
Link to this Philo?
tcm glx wrote:Link to this Philo?
I'll have to dig up the part numbers.
- ckymacias
- Bronco Info: 1987 Bronco 302 4x4 with a updated front clip to a 93-97 grill
This is good info, I'm in need of one here soon...
20-6244.philofab wrote:tcm glx wrote:Link to this Philo?
Todd Z.
- Phoenix0783
Wasn't that discontinued?toddz69 wrote:20-6244.philofab wrote:tcm glx wrote:Link to this Philo?
Todd Z.
There are two part numbers. The old number was discontinued and replaced by the new part number.
- ckymacias
Does anyone know the new part number?
Philo, does this bolt in?
tcm glx wrote:Philo, does this bolt in?
Yes, uses factory pulley and hose. No more steering wine.
You will love how quiet it is T. A bit more power as well. At least mine has more. Although, it's only been in there a couple of short years and it's making some noise like it's going bad.tcm glx wrote:Philo, does this bolt in?
yikes wrote:You will love how quiet it is T. A bit more power as well. At least mine has more. Although, it's only been in there a couple of short years and it's making some noise like it's going bad.tcm glx wrote:Philo, does this bolt in?
Right on B, still waiting on Philo to drag up the part numbers.
You can change the pressure of the pump by playing with bypass valve.
20-6244 was changed to 60-7272
As far as coolers, you can probably get away without one on a street or trail rig, but if you push it hard enough and long enough they overheat. When they overheat, you lose the power assist. It still steers, but if you're in the rocks (in Henderson in the summer), you better watch your thumbs because you can't hold on tight enough to keep the wheel from tearing out of your hands. Went to a regular trans type cooler out in front of the radiator, and no more problem. A larger reservoir will only make it take a little longer to overheat or leak out, it does nothing to aid in heat rejection.
I have seen ATF attack seals in power steering systems and turn them into rocks, but then heat and age do that, too. ATF used to be what Ford required in their systems in the old days. Have been using a synthetic hydraulic fluid, and it seems to work fine. The Napa power steering fluid looks just like standard industrial hydraulic fluid in a 1 quart bottle.
Shock oil would work too....
Maybe I'll try some of the red synthetic stuff next time I have it apart.
