Built rear ends: Currie, Camburg, Dirt Tech, Schreiner, etc.
- Bronco Broker
I've been toying with the idea of buying a 9" rear end from one of the above companies for my 86 Bronco build. Does anyone have any experience with them? What's the most bag for the buck? This is one my wish list, this may change due to good new addition info by you fine people:
Standard Bronco width housing
Disc Brakes
1/2 lugs, not 5/8s as I want to be able to swap out a wheel from my of my bronco buddies if need be
31 or 35 spline
Limited slip
4:56 gears
As of right now I don't think I'll need a full floater.
Thoughts?
Disc Brakes
31 or 35 spline
Limited slip
4:56 gears
Thoughts?
Re: Built rear ends: Currie, Camburg, Dirt Tech, Schreiner, etc.
Mitler Brothers used to be, and probably still are, priced very well. As I understand it, they used to (maybe still do?) build housings for other "builders" that simply put their own label on them... worth a look.
Why not just stick with the 8.8 center and have currie run the .25 wall axle tubes and the 9" big bearing ends? Then have the axle assembled. May be cheaper.
Include RuffStuff Specialties in your list as well. Probably a little more than you're going to need for street truck. You can put on whatever ends you want, but you won't be able to buy it complete from them. They have 3/8" tubing, look good, and the center section will give you up to 2" more clearance then a standard 9" housing. As far as budget 9" housings, I think Summit also has one now. I have used Schreiner and Speedway Engineering for 9" floater housings, and they served the purpose they were asked to. Both companies were good to work with. Only bought some 31 spline axles from Currie once, but they provided a good product.
I have a factory housing that has been trussed and aligned, with Currie 31 spline axles, a Detroit, and ran super heavy / high traction Toyo M/Ts. I have so far been unable to hurt anything but wheel bearings (Until I bought the good Timkens) and the factory center section.
An aftermarket housing isn't really needed until after you need bigger studs and 35 spline axles.
That being said I would buy a Ruff Stuff Housing if I did it again. My price on that housing is less an a JY rear to start with and the Giant Truss.
- Bronco Info: 87 Bronco with some Autofab parts held on with bailing wire and duct tape
I'm not thrilled with my Moser. I was told it's "the same as the Currie" . Not even close. Should have spent the extra $200. On a side note, I have been blowing through axle seals. Not sure if it's relative to the brand or not. I have a buddy with another 9" that is doing the same thing. I have a few guys trouble shooting possible origins of the problem. Could be a big ol batch of bad seals shipped in a cargo container from China. Running Timkins, don't really know where they are made... Could be a defect in the race or the surface where the seal makes contact, maybe a bent tube. Both sides have failed several times now. Have not identified the actual problem yet but replacing an axle seal after every trip is getting old. On my next Bronco I'm keeping the 8.8 till if breaks.
- johncharlesb
Sounds like a plugged vent.bajabuck wrote:I'm not thrilled with my Moser. I was told it's "the same as the Currie" . Not even close. Should have spent the extra $200. On a side note, I have been blowing through axle seals. Not sure if it's relative to the brand or not. I have a buddy with another 9" that is doing the same thing. I have a few guys trouble shooting possible origins of the problem. Could be a big ol batch of bad seals shipped in a cargo container from China. Running Timkins, don't really know where they are made... Could be a defect in the race or the surface where the seal makes contact, maybe a bent tube. Both sides have failed several times now. Have not identified the actual problem yet but replacing an axle seal after every trip is getting old. On my next Bronco I'm keeping the 8.8 till if breaks.
Bent housing, vent, or improper installation.
FYI, I have gotten both US and Chinese made Timkens... Guess which I had problems with.
I have a schriener 3rd member with detroit and 4.88. Priced right and good guys to work with, no problems with it thus far.
Sounds like you just need a stock bronco housing with a new center section and a disc brake conversion. Right width, they come with 31 spline axles and you could get the disc brake conversion for cheap as well. Probably all for under 1200. 78-79 Had a 9" with the 31 spline and I think up to 83, but someone correct me if im wrong on that one
Does the78 - 79 axle fit under the 80 - 86?
- ESHALLBETTER
We used Schreiners stuff when we were doing alot of short course racing and had good luck with it. Ron was always a good guy to deal with. I think their good axles for the price.
- Phoenix0783
Yes. That's what I have in mine.AusBroncodoc wrote:Does the78 - 79 axle fit under the 80 - 86?
Ding ding ding - we have a winner. Unless that is you like to spend more $$ than is really needed. Oh wait - it's Chris - this very well may be the case78Class3 wrote:Sounds like you just need a stock bronco housing with a new center section and a disc brake conversion. Right width, they come with 31 spline axles and you could get the disc brake conversion for cheap as well. Probably all for under 1200. 78-79 Had a 9" with the 31 spline and I think up to 83, but someone correct me if im wrong on that one
Oh and 9"s were in up to '87 trucks supposedly. I've personally seen them in and '86. It was the one I butchered!
Cool, I found one locally for a good price, but I donated the money to the WW fund. Oh well, payday is next week.Phoenix0783 wrote:Yes. That's what I have in mine.AusBroncodoc wrote:Does the78 - 79 axle fit under the 80 - 86?
philofab wrote:Bent housing, vent, or improper installation.
The mexican ones!! hahaha
CP.... run the stock one, gear it and call it done... when she starts going, You can have Currie build the 8.8 with 9" ends, and then swap over your gears and LS.
If I did it all over again I would use Moser "Hobby Stock" axles. Bigger diameter between the flange and bearing and also a larger bearing. Requires their ends. A little more than the $400 aftermarket axles cost but addresses the major weak point of semi float axles.
http://www.moserengineering.com/axles/h ... les-1.html
I like my cone rear end. No complaints. Quality unit.
- Agui-E7TE
I think Currie has a Fabricated 9 inch bare housing that goes for $600.....That's what I would go with....well if I wasn't a cheap bastard looking for a junkyard 9 inch.
- Seattle FSB
- Bronco Info: 1990 FSB MAF, 6.7L, Level10 E4OD, Currie F9, ABS Electric Brake Booster
Like this?Agui-E7TE wrote:I think Currie has a Fabricated 9 inch bare housing that goes for $600.....That's what I would go with....well if I wasn't a cheap bastard looking for a junkyard 9 inch.
1990 FSB, MAF, 6.7L, Level 10 E4OD, Currie F9, ABS Electric Brake Booster
