Beginning shock valving point.
- Phoenix0783
I got a used set of King 12x2.5 remote reservoir smoothies that have .008" valving on the compression side and .010" on the rebound side. I'm thinking this is a little soft, especially on the compression. Any recommendations? These are front shock and it's mostly a daily driver, though I wouldn't have a problem with changing the valving for a weekend of playing.
Re: Beginning shock valving point.
Where are they mounted? In front of or behind the coil-bucket? What is the front end doing or not doing? What are you trying to change?
- Phoenix0783
They'll be behind, but attached to the radius arm. I have rs5000's on there now...
- Polarcub
I have 14" kings in front of the beam with .012 Rebound and compression and deaver coils works very well behind the beam I am thinking your going to want to go a bit more on compression???? I suggest you start with what you have in there and go from there it will give you a better idea of what you want/need for your setup
Jeremy
I ran 0.010 on comp and 0.008 reb with the camburg buckets and 5" deaver coils on my DD. I then ran about 220psi. I had a decent ride with those on the street.
- Phoenix0783
Does running more pressure in the reservoir stiffen the shock? To me it would seem that it wouldn't have an effect past the 150psi that is recommended.
I would swap the compression and rebound valving and adjust from there. It'll probably be a little soft on compression and maybe a little fast on rebound but it's a starting point.
You'll also need to valve the rear to compliment the front.
Stiffens compression and increases rebound due to the displacement of the shaft.Phoenix0783 wrote:Does running more pressure in the reservoir stiffen the shock? To me it would seem that it wouldn't have an effect past the 150psi that is recommended.
- Polarcub
As philo already stated yes the N2 pressure will have an affect in my front setup I have found that 225psi is perfect I started at 150, in the rear I am only running 100psi right now. We have played with our N2 pressure in the 9 car and tweaked it to fine tune as well. I knew of a class 1 car that was running 400psi I have been told that most shocks will handle much greater pressure than that as well. What I ma unsure of is adverse affects on the shocks due to high or low pressure. The N2 keeps the shocks moisture free and will also raise the affect the boiling point of the oil as well. What i have seen is that most people will play with the N2 pressure to make minor adjustments to the shocks to make those small adjustments. That is how I ended up with 225 in my fronts. I wanted just a bit more stiffness but not much. One could achieve the same with revlaving but changing the N2 pressure is often less of a headache if things are almost there.Phoenix0783 wrote:Does running more pressure in the reservoir stiffen the shock? To me it would seem that it wouldn't have an effect past the 150psi that is recommended.
Jeremy
- Deleted Account
I run about 300 psi in the race truck. I run alot of valving and it keeps the floater piston in resi from blowing back as much in hard impacts.
Mark Kiefer
Southwest Performance
858-449-2292
Pics
858-449-2292
Pics
Increased gas pressure increases rod force, nothing more, nothing less. It has nothing to do with valving unless you are not running enough pressure for the valve stack you are running and your shock is cavitating.
Increasing gas pressure is a a good cheat for lack of spring combinations or preloadability.
