In tank pump for LS/LT swap
XLR8
Bronco Info: 1995 Bronco XL
Post by XLR8 »
I'm working through my punch list for my L86/8L90 swap and have a question about fuel delivery. I know the stock pump can't deliver what's needed, i'm told i need at least 310 LPH rate and somewhere around 70 PSI at the fuel rail. I've also seen where people plumb in a Bosch 44 pump after the in tank pump but i'm worried about having a second pump to deal with and if the stock intank pump can take the pressure. I'm thinking of just buying a new tank and installing a new in tank pump but not sure what will work.
Does anyone know what others have done?
There's not a lot of info out there for swap using these newer LT direct injection motors but that's what i'm using. I'll try and document the build here for others to learn from my mistakes.
My biggest gotcha so far was learning i needed a new 9" rear end to handle the torque but that's a good opportunity to convert to discs. I'm in Texas so local knowledge is hard to come by.
XLR8
Re: In tank pump for LS/LT swap
Post by XLR8 »
Looks like after more sleuthing there is an intank pump I can use here.
https://aeromotiveinc.com/product/efi-r ... ation-kit/
S00TLYFE
Bronco Info: IT RAPTOR NOW
Post by S00TLYFE »
I am looking at getting the new Holley sniper in tank pump unit.
XLR8
Post by XLR8 »
Thanks for the link. I ended up buying an Aeromotive 340 setup and a new tank. Going to cut a drop in this pump but leave the old pump (disconnected) and just use it for fuel level to my AIM dash.
S00TLYFE
Post by S00TLYFE »
Wrightracing.net wrote:
Mon Jan 03, 2022 9:16 am
i dont know much about the holley one but the quantum was easy to install, and i used aeromotie 13102 for my psi regulator, they install in factory locations
S00TLYFE
Post by S00TLYFE »
XLR8 wrote:
Mon Jan 03, 2022 9:44 am
nice, let us know how it works out for you
XLR8
Post by XLR8 »
LT swap is up and running! It's going to be amazing. Splurged on a Camburg 9" rear with 35 splines and TT hubs.
Here's the fuel setup.
And other stuff.
Hillbilly Heaven
Bronco Info: 1979 Bronco 545 swap 6R80 D60 front and 10.5 rear. Use for expedition camping go fast when at home
Post by Hillbilly Heaven »
Wonder if that fuel pump setup would work with the poly tank as well?
Hillbilly Heaven
XLR8
Post by XLR8 »
I don’t see why not.
toddz69
Post by toddz69 »
Hillbilly Heaven wrote:
Tue Mar 08, 2022 6:00 pm
I'm sure it would - those Aeromotive pumps/kits are fairly universal.
Todd Z.
