ISO Preferred spring rate and initial valving front
EASTCOUNTYBRONCO
Bronco Info: 88 brick nose doing ls swap and 4.5 over Oocho beams and links
Post by EASTCOUNTYBRONCO »
I am looking for a little help on choosing an initial spring rate and valving for my front coilovers. I am running a 1990 bronco 4.5” over Ocho beams LS3 with 3.5 5-tube bypass and 2.5 coilover on the front. Entire rig has 2” roll cage and will be on 37s. Any help or suggestions will be greatly appreciated thank you.
Re: ISO Preferred spring rate and initial valving front
What tube layout on the BP's?
CO 15 comp/ 8 rebound , 3 bleed holes open. 450/450
BP 20/8's no bleeds open. If it doesn't have overlapping comp tube you may want bleed poppets.
What Brian said....
Brian do you do 12/16 spring length on a 14 inch C/O? with that rate?
14/16 usually.
a copy...
I know this is a 3 year old thread, But I will be running 2.5x16 fox coilover's and a 2.5x16 bypass. The coilover's will be running a 16"x500lbs and a 16"x450lbs springs. What kind of droop should I expect with minimal preload. The Bronco will have a 351w, C6, steel fenders and hood.
I was just wondering a ballpark number.
David
Stock width? I ran stock width 400/500 and was at 1 1/4" preload. Now on 350/450 and figuring 2" preload. I had a windsor in my old bronco and a 302 in Carly's .
+3, per side
David
