Injectors for 351w with k&n intake and bbk twin 57mm tb
95Bluwhale
Bronco Info: 1995 ford bronco 351w xlt
Post by 95Bluwhale »
I have a dilemma I need to get some bigger injectors and not sure what would be best I have the k&n intake system and the bbk twin 57 mm throttle body and msd distributed and wires so I want to get my power and torque up with Bolt on’s any other recommendations would also be helpful nothing else on the motor is aftermarket
95Bluwhale
Re: Injectors for 351w with k&n intake and bbk twin 57mm tb
56mm throttle body sorry
S00TLYFE
Bronco Info: IT RAPTOR NOW
Post by S00TLYFE »
95Bluwhale wrote:
Sun Aug 23, 2020 1:55 pm
you don't need to get different injectors with a throttle body and cold air intake, if you were going to do heads cam and intake manifold too, then you would want to step up to 24lb injectors
95Bluwhale
Why not I already have more air going in to the engine more fuel would help to
Save your money for good heads. Your ECU will easily compensate for your current intake mods. You're injectors are nowhere near maximum capacity.
